Engine will not start..
Old Jul 1, 2011 | 07:08 PM
Jay_Mills's Avatar
Default Engine will not start..
Hey H/t
yet again another problem with a honda not starting..
So today i started my car let it run for a bit, after letting it run for a little i turned the car off and let is sit for a minute while i got dressed. So after getting dressed i go back down stairs to leave and my car does not wanna start.. I checked the dizzy for spark, checked the fuel pump, Main fuse etc.. But also i noticed that when i have someone try and start my car for me the ground wire from the engine to the chasis is smoking and getting really hot? Any Ideas?
Old Jul 2, 2011 | 12:46 AM
mouab18c1's Avatar
Default Re: Engine will not start..
Sounds like you have a short somewhere.
Old Jul 2, 2011 | 05:46 AM
fcm's Avatar
fcm
Old Fart
Check your main power connections, start with the grounds, batt. clamp to batt. post, batt. to chassis and chassis to engine, do not just eyeball the connections, remove/undo them, [paying close attention to the chassis to engine ground] clean to bare metal both contact surfaces, reconnect making sure connections are snug/tight, careful not to over-tighten. 94
Old Jul 2, 2011 | 09:14 AM
Jay_Mills's Avatar
yea i figured that would be the problem.. i just didnt want it to be true..
Old Jul 2, 2011 | 09:15 AM
Jay_Mills's Avatar
should i upgrade the gauge of the ground wires?? you think that would be better?
Old Jul 2, 2011 | 09:45 AM
Drive 4 fun's Avatar
Stock guage is not the problem if the connections are good. You could smoke a lead and need to replace it because of that. Unless you have something with huge draw, or a partially broken lead, then it is more likely connection than size. You can't always look and see a problem. As FCM says above, clean and redo connections.
Old Jul 3, 2011 | 06:39 PM
jwaym24's Avatar
Most deffinately. I 3rd that. Size only matters well....lol anyhow. A bad connection can cause lotts of issues. Recently my car had a similar problem after swapping the gsr in my ek Minus the smoking. No start. Was a loose main ground
Old Jul 3, 2011 | 08:19 PM
Jay_Mills's Avatar
okay cool.. im do all this stuff you guys said.. and check everything because i didnt have any of these problems untill i did the ls swap soo yea.. but hopefully after i get everything figured out and my head gasket changed again.. then the engine will start running smoothly and such.. but thnx again to everyone who responded..
acuraTboo
Honda Civic (2006 - 2015)
Apr 24, 2013 04:16 AM
540dude
May 6, 2012 08:17 AM
speed488
Engine Management and Tuning
10
Jul 12, 2011 09:15 AM
1988crxdx
Apr 5, 2010 08:28 PM
datbuoylex69
Dec 13, 2002 06:28 AM
