Wheel hop when cornering...
Ok this has me baffled, firstly i've done 30+ track drives and i generally know how to drive so this is not from me getting on the power early that's causing it.
It only happens with the wheel turned left round a corner and accelerating, doing this exact same motion at the exact same speed going the opposite way i get no wheel hop at all.
I personally think driver side upper engine mount.
The car has
Roll centre adjusters
Super pro LCA bushes
steering rack riser
new OEM track rod ends
Buddyclub N+ coilovers
Front, rear and gearbox mount inserts
-2.5 neg camber up front.
Car has done 110k
Any thoughts, i'm thinking the engine mount, there is also slight play in the drivers side wheel when holding the wheel at 8 and 2, no play at 12/6 or 9/3. I believe that play is down to the slider inside the rack as it has the same on the passenger side but not as much.
Any help apprciated.
Cheers
The car has
steering rack riser
Car has done 110k
Cheers
