fuel pump problems
Old Jul 1, 2011 | 12:01 PM
gwarbmx's Avatar
Default fuel pump problems
when i turn on the key nothing. i removed the back seat took off the plate and took two wires off a drill battery and tested it. it worked from that spot and i seen some rigged **** by the door under the carpet. it worked there when i tested it. i fixed that problem with some shrink wrap. i went to test the wires by the relay and nothing. i thought it was the relay before i started any of this. i got a new one and a new key switch and still nothing. i was wondering if i just toggle it but that sounds like a retarded *** plan. any thought on what to do? if its screwed i have a 91 civic si i can rebuild. leaning more on that side cause this 89 dx is getting to much for me to handle.
Old Jul 1, 2011 | 04:33 PM
rstchris's Avatar
Default Re: fuel pump problems
Is the ecu "known good"? There are not very many things that will cause the pump not to prime.
Old Jul 1, 2011 | 04:48 PM
WanaBeFaster's Avatar
Take a test light and check for a good ground at the pump and at the relay. you could have loose or bad ground.
Old Jul 1, 2011 | 07:01 PM
gwarbmx's Avatar
i think its the ecu. i have a 93 accord lx auto on it. i'll try my pm6 ecu.
Bushybob94
Jun 5, 2018 11:40 AM
gitchesum
Feb 28, 2009 05:39 PM
markD.
Aug 21, 2006 09:12 PM
b18-c-rx
10
Jul 17, 2005 02:10 PM
b16a1sirhb
Apr 9, 2003 11:50 PM
