no cel light and diagnosis plug wont read
Old Jun 30, 2011 | 06:09 PM
sikvic00's Avatar
Default no cel light and diagnosis plug wont read
I just bought a car and it has a few problems. Vtec will not engage and smokes when its in the high rpms only. Its a jdm B16a. Also has a fluctuating idle sometimes. So i went to Advance and tried to see if i had any codes throwing and the scanner couldnt read anything. I've also notice that the check engine light doesn't even come on when the key is on. so i checked to see if it had a bulb or if it was burnt out. It had a bulb and the bulb was good cause i switched out with the oil light one and it worked. So what could be the problem?
Old Jun 30, 2011 | 06:48 PM
virgineg6's Avatar
Default Re: no cel light and diagnosis plug wont read
Jdm ecu? They use a different software so those scanners wont work!
Old Jun 30, 2011 | 09:15 PM
Wrona's Avatar
Jump the harness on the ecu
Old Jul 1, 2011 | 03:19 AM
sikvic00's Avatar
Yes a jdm b16a sir 2 ecu obd1
Old Jul 1, 2011 | 03:21 AM
virgineg6's Avatar
but what ecu?
Old Jul 1, 2011 | 04:44 AM
sikvic00's Avatar
Its a p30 from a b16a jdm spec engine obd1... Dont really know what else to say or explain?
Old Jul 1, 2011 | 04:46 AM
sikvic00's Avatar
how do you jump the harness?
Old Jul 1, 2011 | 04:47 AM
soon2bdropped's Avatar
if the car is obd2 with obd1 ecu it wont read..
Old Jul 1, 2011 | 05:30 AM
sikvic00's Avatar
Shouldnt i have a cel light come on, when i turn my key on, no matter if the ecu diagnosis plug / ecu cant read ?
Old Jul 1, 2011 | 10:36 AM
sikvic00's Avatar
can someone answer this question?
Old Jul 1, 2011 | 12:39 PM
civicek83's Avatar
yes, your cel light should come on when you turn the key. at least it did on mine and then went off
Old Jul 1, 2011 | 01:41 PM
sikvic00's Avatar
Well mine doesn't come on at all. Even with it jumped in the blue plug or when i turn the key on. I know the bulb is good be cause i replaced it. what else is causing this?
Old Jul 1, 2011 | 02:35 PM
sikvic00's Avatar
Help cant figure this out?
Old Jul 1, 2011 | 02:49 PM
civicek83's Avatar
here is some info that could be useful
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/check-engine-light-not-coming-not-bulb-cluster-2436997/
Old Jul 3, 2011 | 07:37 AM
sikvic00's Avatar
If my ecu is bad what would be a sign that it is?
Old Jul 3, 2011 | 07:51 AM
grumblemarc's Avatar
The Grumpiest
Did you check that the CEL actually works? I'm not talking about the bulb.
Did you read the thread at the link provided to you in post #14?
Old Jul 5, 2011 | 06:00 AM
sikvic00's Avatar
Yes i read it. I will check again to make sure the that the wire is connectected. will this wire be on my original ecu plug or the jumper plug?
Old Jul 7, 2011 | 02:52 PM
sikvic00's Avatar
ok im trying to check a13 but im confused . i have a 00 civic cx. it has a b1a swap. When looking at the harness i have 4 plugs in the jumper but one doesnt go to anything its like a empty plug. Is this harness a automatic? Is my "A" plug harness the one that is the one connected to the cabin harness? a13
Old Jul 8, 2011 | 07:19 AM
sikvic00's Avatar
bump
Old Jul 9, 2011 | 04:17 AM
sikvic00's Avatar
Any help..
Old Jul 9, 2011 | 01:49 PM
sikvic00's Avatar
help
z6hatchboy
Sep 16, 2010 04:16 PM
b16bri
Dec 2, 2007 08:36 PM
phat_gsr98
Jul 13, 2004 05:40 AM
