how to jump the service port???
obd1 or 0 i had the same problem when swapping my obd1 ls into my ef. it turned out to be the jumper harness. i wired the dizzy sensors into the the jumper harness. but check the check engine code
Turn the ignition to ON (II). Pull back the passenger side carpet and see if the little light on the ECU is blinking. Count the number of blinks. There may be more than one so, watch and count several cycles to make sure you have the right code(s).
if this is the first time the car has been run since its been wired I'd be willing to bet you got a couple of dizzy wires switched.
type "Honda OBD-0 codes" into google for the code list.
cannouu
Engine Management and Tuning
Jun 28, 2012 10:17 AM
ViXoN Hatch94
Jun 21, 2006 12:43 PM
