97 civic d16y7 chugging?
Old Jun 30, 2011 | 10:59 AM
rewerbcrx's Avatar
Icon2 97 civic d16y7 chugging?
about 3 weeks ago my car started to chugg while driving on the highway. doing about 70 mph.
i have since then replaced::::::: the spark plugs,wires dizzy cap, rotor, and the farthest right injector.
i replaced that injector because i wasn't getting spark in that cylinder but when i pulled the plug off while running nothing changed.
i then compression checked each cylinder. farthest right had NONE.
still chugs at all rpms and speeds.
my question.........
WHAT DO I NEED TO FIX NEXT?
could it be an exhaust valve stuck open? just a quick valve adjustment fix do it?
CODES: PO301, P0303, p1399 and one other i can't remember.
and the check engine light will blink if i maintain an easy throttle at any speed.
thanks its been awhile since i posted.
Old Jul 1, 2011 | 06:13 AM
rewerbcrx's Avatar
Default Re: 97 civic d16y7 chugging?
PLEASE HELP.... i can't be the only one...
Old Jul 1, 2011 | 08:17 AM
hondamark35's Avatar
no compression.. none?! how are the other cylinders? could be a valve(s), hole in the piston, even a hole in the head... but i don't think that's too common with these motors.
if compression is ok on the other cylinders and timing is on, i'd pull the head off and find out what the deal is.
Old Jul 1, 2011 | 08:56 AM
grumblemarc's Avatar
The Grumpiest
If you did the test correctly then this is your problem.
Old Jul 3, 2011 | 05:57 AM
rewerbcrx's Avatar
i know that would be the problem. before i start tearing apart my DD i would like to get insight on what could cause it just to go. kinda weird it did it while i was normal easy driving highway
Old Jul 3, 2011 | 06:02 AM
The Grumpiest
Who cares what would cause it? Just fix the problem. Your car is 14 years old. Things are going to start breaking now.
Do the test over just in case you did it incorrectly. If it's correct you're gonna have to pull the head any way.
Old Jul 3, 2011 | 07:30 AM
redm3turbo's Avatar
a CEL blinking is a bad thing....
Id pull the head off either way
Old Jul 3, 2011 | 07:35 AM
The Grumpiest
I just replaced the engine in the hatch because it had similar symptoms.
Old Jul 3, 2011 | 09:54 AM
rewerbcrx's Avatar
Thanks
slobalt716
Mar 20, 2015 12:19 PM
Lee Williams
Nov 24, 2014 08:18 AM
thesandmn
10
Jul 8, 2014 09:32 PM
turboD_EG
Apr 17, 2009 07:19 AM
dhatcher2002
Nov 25, 2008 10:26 AM
