help/tips intercooler pipe
i've got everything installed, last thing i need is the intercooler piping. what i am going to do is order the piping i need online. this is the first time I've done this so any tips or help will be appreciated. first, do any of you have a good way to determine what pipe your going to need before you buy it? i have an idea of what pipes i need, but i want to make sure that they will work before i order them. do they ends need to have the beaded edge on them in order to stay connected? if i have to cut the end off, can i just connect with the silicone coupler and not have to worry about them blowing off?
any other words of wisdom that will help me do this right, with little aggravation would be great.
thanks
Joe
thanks
Joe
that pipe doesn't quite fit my car. i was going to use a 2.0" to 2.5" 90degree coupler going from the turbo, straight pipe to a 180 which should mount to the intercooler. on the other side i'm going to need possibly a 180 which will mount to my AEM. i just need to verify this before i buy the pipes. although if i can get a kit that includes the charge pipe to the throttle body for that price, it would be nice too, so i wouldnt have to weld the BOV to my AEM.
Pipe with the beaded ends will work well and not blow off as easily as pipe without beaded ends. However as long as you use tbolt clamps and not worm type there should be no issues with either u choose. Another tip if u experience blowing them out you can try and it has worked for me is before assembling each coupler together spray hairspray on the ends of the pipe or in the coupler then assemble. When it dries it acts like glue but is easily taken apart by hand and helps keep you from blowing them apart.
Check out this kit. I have this on my civic. Fits perfect and has everything you need.
http://www.go-autoworks-store.com/go94incuraki.html
please please please buy some decent t bolt clamps. i cheaped out on them and got worm-drive clamps, had so many leaks from them. finally just spent the money and did it how i should've the first time.. no more leaking
I'm definitly going to get t-bolt clamps.
anyone have any advice on how to decide what pipes i need before i order them? do most of you just eyeball it?
try here:
votionspeed.com
frozenboost.com
get all the **** you need. use the least amount of couplers u can (meaning get as much welded as u can.)
votionspeed.com
frozenboost.com
i had a fabricator take a look, and he was going to charge me 550 to do the piping (using my AEM) as well as weld a bung on my oil pan, weld flange on downpipe, and weld flange for BOV.
does that sound a bit pricey to you guys? thats why i figured i would do the piping myself, i'm still going to need to get the welding done. i'm wondering if i at least get the piping where it needs to be, and then have it welded, if that might save me some money.
No prob man. Just lookin out for you. Call greg if you have any questions. everything will fit like it was stock
Btothe3rdDegree
Jun 30, 2004 01:49 PM
