FS: Hondata S200 with boostand S300
I have two hondata equipped ecus that both work properly; I just don't need either of them anymore.
The first ecu has S200 boost and it is an OBD1 P75. Looking for $300
The other ecu is equipped with S300 and it appears to have been a P28 that was converted to be used with OBD2A and B without the use of a jumper harness. It actually accepts the OBD2 plugs right into the ecu through a built in conversion. Check the pics if you are confused. Looking for $500.
As always offers will be heard, but please be realistic. Thanks!
