Chipped p28 basemap suggestions?
Old Jun 29, 2011 | 09:34 PM
mdrshewrote's Avatar
Default Chipped p28 basemap suggestions?
As of now I'm running stock gsr with a blox intake manifold and a P28 chipped and the basemap was hybrid to gsr and b16 from my mechanic and possibly running more aggressively. I recently failed my emissions could this be a problem? O2 is plugged and a new cat converter was installed. Should I get it gsr base map so it wouldn't be using more fuel which possibly Why I failed? Thx
Old Jun 30, 2011 | 01:48 AM
GhostAccord's Avatar
Default Re: Chipped p28 basemap suggestions?
A basemap would not be the best solution to pass emissions. You probably didn't need to replace the O2 or the Cat. If you want to pass emissions you should run a stock GSR ECU. or pay to have your chipped P28 tuned properly.
Old Jun 30, 2011 | 06:40 AM
A tuner shop is re-chipping my p28 cause my basemap was too aggressive and putting out more fuel. I failed the HC (burning too much fuel/oil) and CO (Dirty intake filter etc.) I'm having them re-do everything cause it was hard chipped from previous tuner, to GSR basemap with knock sensor off and IAB (secondaries off) since I run a ITR style intake manifold on my GSR. The base map would put it back to stock gsr so hopefully this would help alittle. I did not replace my O2 perhaps I should, just my cat was new. I was just suggesting if GSR basemap would be best? and what do you mean TUNE my P28?
Old Jun 30, 2011 | 07:18 AM
kyden's Avatar
i suggest you stop using basemaps and have someone actually tune the car.
Old Jun 30, 2011 | 08:35 AM
MR.johnson's Avatar
Old Jun 30, 2011 | 10:22 AM
Well I plan on getting headers, cam gears, and throttle body. Should I wait til I get them installed and get it tuned? My motor is bone stock. I plan on doing a tune to my car later or now?. Will I have to tune it again when the new aftermarket parts are installed? The shop offers $80 per hour on the tune. I don't know how long tuning may be.
Old Jun 30, 2011 | 11:32 AM
MR.johnson's Avatar
to tune a bolt-on n/a honda should not be more than a hour to tune.
Old Jun 30, 2011 | 11:43 AM
I think I answered my own questions guys, thanks for the help. Once again my motor is bone stock with a Blox IM which can do for now. I'll be running stock GSR spec on my P28. YES I will get a tune as soon as I get more aftermarket parts installed. thanks again.
Old Jul 5, 2011 | 11:32 AM
ktsciv93's Avatar
should just run a stock gsr map...
with o2 connected you should pass emissions. it would actually b slightly lean because of the intake mani plenum
worx
Jun 26, 2009 11:59 AM
SLow-Side
Sep 28, 2004 08:05 PM
racuss6
Jun 22, 2004 08:51 PM
TEGPOWER44
Jan 8, 2003 11:31 AM
