ecu question
Old Oct 1, 2002 | 05:51 PM
AZcivicHeat's Avatar
Default ecu question
Can I use the ecu from my '93 civic ex when swapping a b18c with b16a head into my car, or will I need an OBD-II ecu. I know that I will need OBD-II wiring harness and distributor, etc., but I was wondering about the ecu.
Old Oct 1, 2002 | 05:55 PM
poison's Avatar
Default Re: ecu question (AZcivicHeat)
yes you can use it if you convert the harness from OBDII to OBD1 if the engine is from OBD2. Your car will run like crap but will run.
I would suggest if you want to run OBD1 then get the P28 chipped.
Old Oct 2, 2002 | 03:44 AM
jmm96gsr's Avatar
if u want your car to run right you have to get your p28 ecu chipped to run a dohc vtec. you can use what ever wiring harness came with your engine. as for the distributor it doesnt matter if its obd1 or 2
sd619jef9
Nov 8, 2012 01:56 AM
6kZ
Jul 23, 2006 08:31 AM
MaxxdoutSRT4_EK9
Jun 26, 2005 10:23 PM
importpower
Feb 10, 2004 08:34 PM
insomniac791
Dec 8, 2003 04:19 PM
