Turn key, hear click under dash, but starter doesn't turn
Old Jun 29, 2011 | 03:09 PM
follie gatts's Avatar
Default Turn key, hear click under dash, but starter doesn't turn
Could I have ruined something during the compression test I just did? I hear a click under the dash each time I turn the key, but the starter doesn't try and turn the motor.
Old Jun 29, 2011 | 03:27 PM
Drive 4 fun's Avatar
Default Re: Turn key, hear click under dash, but starter doesn't turn
Battery? Connections? If you have a voltmeter/multimeter check battery voltage with attemt to start, poor man's load test.
Old Jun 29, 2011 | 03:51 PM
The behavior persists when connected to my other car with jumper cables, and I tried with the other car off and running.
Old Jun 29, 2011 | 04:05 PM
lemontit's Avatar
Have you been working on the engine or did it just catch the symptom? If you've been working on it, it could have a loose ground.
Old Jun 29, 2011 | 04:11 PM
94VTEC2TONE's Avatar
tap on your starter and see what it does, i have what would seem to be the same problem last week
Old Jun 29, 2011 | 04:38 PM
Seems to mean not the battery, so, connections?
Old Jun 29, 2011 | 04:44 PM
dntnedvtec's Avatar
Either faulty grounds, dirty connections. Those are free to check, and easy to do(Clean them up, tighten all connections). If the problem persist, then look towards your starter going. Pull your starter, and guess wht? It should be free to check at your local auto store. Good luck.
Old Jun 29, 2011 | 05:35 PM
The grounds were fine when the car ran and while I was doing the test. I checked the negative battery terminal ground with my multi-meter and it was good. I am making the assumption that the others are OK.
I took the intake off to find one of the cap bolts I dropped onto the transmission. I put it back on after the test, fully anticipating to drive it away, but it doesn't try to turn over. I checked fuses, and they are all OK.
If the relay is fried, would it still click? Will a starter die without any warning?
edit: you are probably wondering why was I removing the cap. I wanted to see if the points on the cap were worn to determine if I should replace cap and rotor. I put those parts back. I'm not getting that far if the starter isn't turning, though, right?
Old Jun 30, 2011 | 06:51 AM
JulieU's Avatar
Sounds like the contact in the starter. I've had to have mine replaced twice now (just the contact, not the whole starter).
Old Jun 30, 2011 | 08:04 AM
DAgsrt's Avatar
check for voltage to starter if has voltage then make sure it has good ground. should ground through case. if all is good then you have a bad starter. if you do not get power to starter then you have electrical system problem then you need to chase the wires till you find the cuilprit.
Old Jun 30, 2011 | 08:05 AM
DAgsrt's Avatar
good luck
Old Jun 30, 2011 | 08:10 AM
DAgsrt's Avatar
also doing a compression test you have to crank the vehicle correct. so you may have had a weak starter and by cranking over and over it finally gave out. just a possibility?
Old Jul 4, 2011 | 01:03 PM
i pulled the starter and cleaned up the copper contacts with sandpaper. when i apply 12 volts using the battery or a charger, nothing happens. the helms says i should hear the solenoid click, but not much else in the case that nothing happens. i'm going to dig into the dealer service manual now.
Old Jul 4, 2011 | 01:33 PM
i'm an idiot. i didn't have the solenoid wire plugged in. it works. thanks for all your help, guys.
Old Jul 4, 2011 | 02:10 PM
Thanks for finishing and posting the answer. Threads are not as helpful without an ending.
Old Jul 4, 2011 | 06:26 PM
fcm's Avatar
fcm
Old Fart
X2^^^
Props to the OP for posting the solution, even though it was his silly mistake, most would not have. 94
Old Jul 7, 2011 | 06:34 AM
DAgsrt's Avatar
yeah you gotta hook up all the wires. no biggie at least it was a cheap fix.
backjack
Honda Civic (2001 - 2005)
Feb 20, 2013 06:57 AM
nomotorsol
15
Mar 1, 2005 08:21 PM
es_squared
Oct 16, 2004 02:10 PM
darrinbrewer
Jan 13, 2003 09:49 PM
