Integra master cylinder
Old Oct 1, 2002 | 05:38 PM
phoenix's Avatar
Default Integra master cylinder
I've got an '89 Si and I was wondering if I could bolt on the larger (or so I've heard) master cylinder from an Integra (no ABS). If so, which year?
Old Oct 1, 2002 | 06:35 PM
crxjdmsir's Avatar
Default Re: Integra master cylinder (phoenix)
To do Integra you will need to do the booster too. 88-91 Civic EX is a direct bolt up and the same size as Integra. But if you want Integra it is 89-93 that you need.
[Modified by crxjdmsir, 3:37 AM 10/2/2002]
Old Oct 1, 2002 | 07:15 PM
Francois's Avatar
Default Re: Integra master cylinder (crxjdmsir)
Prelude Non abs 90-91 is bolt-on.
15/16 is the diameter.
Old Oct 1, 2002 | 07:45 PM
chhuong's Avatar
Default Re: Integra master cylinder (Francois)
How about the brake boosters?? Are they all the same as in, is a civic 91 dx the same as the integra non abs, or the prelud non abs???
Old Oct 2, 2002 | 12:31 AM
S13 slide's Avatar
whats the size for the stock si? and whats the size for the teg? thanks
Old Oct 2, 2002 | 01:07 AM
crxgurlllll's Avatar
stock 88-91 crx si/dx master cylinder is 7/8"
stock 90-91 Civic EX master cylinder is 15/16" and is a direct bolt on to the crx
stock 90-93 non abs integra is 15/16" as well but will also require that you swap out the booster
Prelude/Accord Master Cylinders will also bolt up to the stock crx/civic booster and are 15/16"
Old Oct 2, 2002 | 03:58 AM
primoEF's Avatar
Default Re: Integra master cylinder (eraser)
nice info, thx
Old Oct 2, 2002 | 04:16 AM
Bontke's Avatar
Default Re: Integra master cylinder (b18k1)
Just what are the benefits besides sensitive brakes?
Old Oct 2, 2002 | 03:00 PM
Francois's Avatar
Default Re: Integra master cylinder (Bontke)
Hum..hum....
I believe the stock Rex and Civic even the Si have 13/16 M/C.
Only the CRX Si 90-91(w/4 wheel disk)have the 7/8 M/C.
A for what a bigger M/C will do....
With the same pedal travel,it meens,the M/C will supply more fluid pressure to the caliper.
Yup,they are going to be more sensitive.
WhiteSlips
Oct 20, 2011 08:40 AM
Another Drew
Jul 4, 2005 06:35 PM
Ballade
Jul 3, 2004 06:46 PM
DANG YO
Sep 27, 2003 04:35 PM
