f20b piston rod custom
Its just a 95mm piston man nothing special if your going low compression . A f22 piston works fine just order a 10.1 if you want 9.1 because of rist pin location. The calculator chart is pretty close on this .
DC4_MADMAN
10
Aug 23, 2006 08:52 AM
20, 50, calculator, comp, compression, custom, displacement, f20b, find, honda, low, os, piston, pistons, rods
