Exedy OEM vs. Exedy Stage 1 vs. Honda OEM
Old Jun 29, 2011 | 09:48 AM
RGoose18's Avatar
Default Exedy OEM vs. Exedy Stage 1 vs. Honda OEM
I need a new clutch. This is for a 90% garage queen (3,000 miles/yr), 10% track/autox car.
Exedy OEM is dirt cheap. For those of you who have experience w/ each I'd appreciate some recommendations. Also after searching I've seen quite a few exedy failure threads, is this still an issue?
Old Jun 29, 2011 | 10:32 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Exedy OEM vs. Exedy Stage 1 vs. Honda OEM
The OEM clutch is perfectly fine for what you said you'll be doing with the car. Why look at something else that might have questionable history?
FWIW, the OEM ITR clutch part number is now superceded with the 92-96 Prelude VTEC part #. I didn't really see that as a bad thing, either.
Old Jun 29, 2011 | 11:29 AM
get RIGHT's Avatar
I was in your exact same predicament last year with nearly the same needs. As Todd said OEM is just fine for your needs but for the costs I ended up going with the Excedy stage 1 with lightened flywheel. Havent had any issues at all. I broke it in at Expo 10, the hard way.
I went with it because the costs of OEM was immense vs aftermarket and I wanted to retain a stockish pedal feel. It has done what I wanted it to do and the lightened flywheel turned out to be a nice touch as well.
Old Jun 29, 2011 | 11:34 AM
Tekkaboy's Avatar
Exedy and Daikin (OEM) are the same company.
Old Jun 29, 2011 | 11:38 AM
racebum's Avatar
i would get the stage 1 if you do any real hard driving and here's why
the throwout bearing in the oem kit is a unsealed ballbearing that does not like being hit hard
the stage 1 plate and disc and reinforced and MUCH less likely to come apart. i've personally popped a spring out of an oem during autocross.
Old Jun 29, 2011 | 11:40 AM
Drive 4 fun's Avatar
I thought Exedy/Daiken made the OEM. I recognize that OEM could set its own standards, but Exedy quality seems good enough to make OEM. For the price, Exedy OEM, or Stage 1. I have the Stage 1 and like the feel of a little more tension, especially for track. I did not pay the extra for the lightened flywheel and kept the cost down. Just had opportunity to see the clutch, tranny change, at 35k, and even the mechanic said looked almost new.
Old Jun 29, 2011 | 12:16 PM
FULLYBUILT2.0's Avatar
OEM...Original
Old Jun 29, 2011 | 12:18 PM
racebum's Avatar
thought fuji carbon made the OEM clutches that actually came with the car
i know exedy is an oem manf but didn't think it was what actually came on the car
Old Jun 29, 2011 | 12:46 PM
Todd00's Avatar
I've done a ton of autocrossing and never once have I had problems with the OEM clutch (on any Honda/Acura). Usually, you only make one or two shifts during a run, anyways. And you don't need to abuse the hell out of the launch, either.
Old Jun 29, 2011 | 12:53 PM
ITR-965's Avatar
I have driven with both the stock ITR and Exedy stage 1 and I loved the Exedy... The pedal felt very good and wasn't much more tension than the stock but it was enough to notice...
Old Jun 29, 2011 | 01:49 PM
vladd's Avatar
I had an Exedy stage 2 in my 99 GSR, when I was installing it the throwout bearing looked EXACTLY the same as the stock one that I pulled out of the car; same markings and everything.
Old Jun 29, 2011 | 01:58 PM
citrus3000psi's Avatar
I've ran, oem, stage 1 and stage 2. Stage 2 is far the best.
Oem was way too soft for me.
I liked the feel of the stage1 and grip was great.
I'm on a stage2 now, and the 3 puck isn't bad at all. Has almost the same pedal pressure as stage1, maybe a weee bit more pressure. But the engagement is quick and to the point; which I like.
Old Jun 29, 2011 | 02:10 PM
siguy9900's Avatar
Originally Posted by FULLYBUILT2.0
OEM...Original
Im with this guy! I had an exedy with a lightened flywheel in my EM1 and I prefered my ITR with a stock clutch set up! My ITR is 90% garage queen and 10% track too! My .02
Old Jun 29, 2011 | 02:35 PM
RGoose18's Avatar
Thx for the replies
So for the record, how much a difference is there between exedy OEM and Honda OEM???
Old Jun 29, 2011 | 02:43 PM
get RIGHT's Avatar
I recommend also buying your Excedy products from BlueR. Cheapest anywhere! When I was pricing it all out, I could have bought 2.5 Excedy stage 1's for the price of 1 OEM. It made my chioce easy. BlueR had it to my door in like 48 hours or less.
I think you know where to find him.
Old Jun 29, 2011 | 03:02 PM
RGoose18's Avatar
Haha, yeah, I'll def. be hitting him up if I decide exedy over OEM Honda. Still would like to know what the differences between OEM exedy and OEM honda are.
Also, I remember reading threads where the stage 1 gave the driver some sort of pedal issue, can anyone comment on this?
Old Jun 29, 2011 | 03:04 PM
3-4 years, no issue here. Slightly more firm pedal which I like.
Old Jun 30, 2011 | 10:27 PM
JDMFreak_DC2's Avatar
MONO LOCO y0!
x2, I purchased my Exedy stage 1 from BlueR, and his shipping is always on point. As Shawn mentioned, a stage 1 with a lighten flywheel will serve you perfectly
Old Jun 30, 2011 | 10:29 PM
racebum's Avatar
a stock honda TB yes, an exedy oem no, honda uses a very high quality TB similar to the stage 1-2 kit. it's a sealed bearing that won't fail nearly as easy
Old Jun 30, 2011 | 10:30 PM
racebum's Avatar
and..........
Old Jun 30, 2011 | 10:31 PM
racebum's Avatar
TB is the big one. the exedy oem kit uses a cheese TB where as the honda oem TB is a much more stout unit, similar to the better exedy TB
Old Jul 1, 2011 | 12:28 AM
eg7's Avatar
eg7
I have had all three, get the stage 1 exedy. its perfect.
Old Jul 1, 2011 | 01:06 AM
RGoose18's Avatar
Appreciate all the responses, think I'll prob. go w/ the stage 1. How much firmer is the pedal feel over stock?
Old Jul 1, 2011 | 02:09 AM
eg7's Avatar
eg7
They reel just right.
Old Jul 1, 2011 | 04:00 AM
R134's Avatar
There were a lot of threads where exedys were cracking, they said it was from the pedal stop not being adjusted or something like that. I'll stick with honda oem when my time comes.
