1988 civic has no spark
Old Jun 28, 2011 | 07:16 PM
dillbrit's Avatar
Default 1988 civic has no spark
my son was given a clean 1988 civic hatchback that has been sitting for the last 5 years. i replaced the dist, plugs, battery, plug wires. timing is set right, engine turns over fine but there is no spark there is power going into the dist but nothing going out. the wiring looks good all the fuses are good, cant figure it out. i was told the crank sensor may be bad and my book doesnt show where it is or what it looks like, any ideas what i can check to fix this would really help. thanks
Old Jun 28, 2011 | 08:14 PM
SuicideError's Avatar
Default Re: 1988 civic has no spark
Hope this helps.
Old Jun 28, 2011 | 08:17 PM
StayKrafty's Avatar
Did you replace the dizzy as a whole or just the dizzy cap? The Crank Sensor is in the dizzy.
Old Jun 29, 2011 | 04:09 AM
anjin's Avatar
Not always - the early models - 87 into 88 - could have the separate sensor as shown on the diagram. At least they do on the jdm and aus models
Old Jun 29, 2011 | 06:30 PM
dillbrit's Avatar
hi and thanks, i replaced the whole dist the old one had alot of corrosion inside and out. it had no spark with the original dist either.
Old Jun 29, 2011 | 06:33 PM
dillbrit's Avatar
hi and thanks. i replaced the entire dist the original one had alot of corrosion inside and out. it had no spark with the original either
Old Jun 29, 2011 | 06:56 PM
1990edsedan's Avatar
Crank sensor is in the dizzy. Now did you replace the dizzy with a rebuilt/remanufactured one or another used one?
Old Jun 29, 2011 | 07:27 PM
racejunke13's Avatar
Grounds?? Or dizzy, or wiring. Possibly ecu but doubtful. Is it dpfi or mpfi?
Old Jul 3, 2011 | 09:46 AM
dillbrit's Avatar
hi i replaced the dizzy with a remanufactured one, all fuses are good, connections are clean, it had no spark at all when my son got the car the check engine light stays on the book says to pull hazzard fuse for ten secs to reset codes but it stays onn still. and when i turn the key on to count the flashes on the ecu nothing happens it doesnt light up at all and it is getting power to the dizzy but nothing comming out. also it says pgm pi on the motor. im about ready to give up, im not good at all with electrical problems
dillbrit's Avatar
Old Jul 3, 2011 | 09:48 AM
dillbrit's Avatar
hi i replaced the dizzy with a remanufactured one. and the car had no spark at all when my son got the car, thanks
Aquila
Apr 5, 2019 01:24 PM
jpino
Oct 1, 2010 10:49 AM
iheartmyctr
Feb 26, 2009 04:36 PM
I8ayellowcrayon
May 1, 2004 07:18 AM
sloweh3
Jan 19, 2004 01:47 PM
