Hopefully found the cure!
Old Jun 28, 2011 | 03:02 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default Hopefully found the cure!
So after not being able to race all summer, I finally decided to buy a CC twin disk my for h22. I was unable to shift at high rpm's at the track, no grinding, just locked out of gear. I would have to idle way down to shift. So after some talking with people and reading some threads I came to the conclusion that it is most likely my clutch. But damn it's expensive, and while Im at it, will get new sychros...anyway, looking forward to the track and hopefully achieve my PB!!
Old Jun 28, 2011 | 04:55 PM
Divers's Avatar
Default Re: Hopefully found the cure!
Wait, it was working fine and then after a new clutch you couldn't shift at high r's regardless of what gear? I'd say it hydraulics or adjustment. Where does it engage? Pedal stop? If it actually is a bad clutch right out of the box I would call the CC dealer you bought it from. Don't just blindly buy a new clutch.
Old Jun 28, 2011 | 05:37 PM
No, I've had the same clutch for two summers. It was working fine at the track when I was making 250whp/198ft lbs and it is still fine on the street, but I'm now making close to 400whp/300ft lbs and even though it works fine on the street, when I took it to the track last summer, I would get locked out at high rpm's. The clutch that is in there right now is a stage 4 Bully, I have not yet used a CC clutch. It engages a little lower than halfway.
lokodog
Dec 25, 2005 09:39 PM
japhonda
13
Jul 30, 2005 01:19 PM
_Endless_
Sep 4, 2004 02:46 AM
wizzards581
Jan 24, 2002 05:44 AM
