Changed CPS, car wont start. Please help
Hey guys, recently my gf's 2005 accord 2.4 started acting up. The car was idling high and revving up and down, when I had it checked out at a friends shop, the scanner found one of the coils were bad. I changed the coil and changed the 4 spark plugs as well as giving the car an oil change. It was working fine for several weeks and all of a sudden the car started idling again, the cel came back on.
When I had the car scanned again, the cam position sensor (b) was the culprit. I purchased a sensor and before installing, I made sure to disconnect the battery. After installing the sensor which took about 20-25 mins, I connected the battery and tried to start the car. The weirdest thing happened, the cel did not blink nor did the battery and the car wont start. It only cranks. All the other lights that are supposed to come on are on but the cel and battery light does not bulb check. I'm sure one thing has to do with the other, but I cant figure it out. Please help.
