Passenger Heated seat
The seat heater itself is probably burnt out. You can remove the plug from the clip and measure the impedence of the heater. There are 3 pins. Black cable from your DMM goes in the middle pin then measure the impedence from the other pins should be around 9 ohms if good. Really high impedence if dead. It's a common failure on all Acura's with heated seats.
correct. i have done a few
