car will not start
Old Oct 1, 2002 | 04:04 PM
blufke's Avatar
Default car will not start
I was driving and the car died. i checked all the relays and replaced them(where is the main relay? not sure if i checked that one). there is no spark and i do not hear the pump priming. wtf is up with my car. checked all fuses also. I even tried to hit it with a hammer. but the car turns over just fine.
oh, and not sure if this means anything but there was a funny smell we couldnt place in the inside of the car right after the car died.
[Modified by blufke, 1:13 AM 10/2/2002]
Old Oct 1, 2002 | 04:09 PM
Dr. EKology's Avatar
Default Re: car will not start (blufke)
battery?
Old Oct 1, 2002 | 04:29 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: car will not start (EKology)
no, not the battery if the car turns over...no spark you say? I would say check your coil, but you also said no fuel! TTT for someone else
Old Oct 1, 2002 | 05:17 PM
blufke's Avatar
Default Re: car will not start (Emerica)
this is the only car i have, any help. please
Old Oct 1, 2002 | 05:23 PM
krazn's Avatar
i would have to say fuel.
Old Oct 1, 2002 | 05:32 PM
phatcivic99's Avatar
Default Re: car will not start (krazn)
what kind of car do you have.
if you have a 96-00 civic then it is your ignition switch. the thing you put your key into. go to honda and get it fixed for free.
Old Oct 1, 2002 | 05:33 PM
blufke's Avatar
but it is not getting any spark
Old Oct 1, 2002 | 05:36 PM
blufke's Avatar
the car is a 5th gen civic, the motor will turn over but will not start.
Old Oct 5, 2002 | 01:19 PM
blufke's Avatar
ALRIGHT! we figured it out. used my old vx ecu and the fuel primed and it started. turned out the funny smell inside was the ecu deciding to crap out. what could have caused it to do that? how can we avoid this problem again?
just opened the ecu up and one of the caps fried and kinda melted the board a little. doesnt look fixable . anyone have an at dx ecu?
[Modified by blufke, 10:34 PM 10/5/2002]
Old Oct 5, 2002 | 06:45 PM
PnX-R's Avatar
Sheesh.. Funny smell in your car?.. Is your ECU fried?.. If so, I can tell you pretty much exactly what happened.
1.. Your ignition coil induced too much voltage
2.. When the fields collasped inside the coil, it took out the despiking diodes in the path to the ECU and fried it.
Hope that shines some light to your problem..
But if your ECU is fine and you replaced all your relays and replaced them all, you might as well replace all your fuses and everything else. Sheesh BUBBA.. Next time, test it before you replace it. Good Luck.. Any questions?.. I would love to answer them..
Old Oct 6, 2002 | 12:50 AM
blufke's Avatar
Default Re: car will not start (PnX-R)
we found out what the problem was by changine the ecu. we were driving and the car just shut off and there was the funny smell. couldnt figure out how all of a sudden there was no spark and fuel, wasnt sure if the smell was it either. we found out what it was by checking it with my old vx ecu. after finding out what the problem was we opened up the fried ecu and found that the 220uF cap was toast. fried the pc board all around it too so i cant fix it.
feava510
Feb 15, 2009 10:59 AM
PinkMaggit
16
Nov 28, 2008 05:25 PM
Matt_2078
Feb 1, 2006 06:02 PM
rocaveli
May 23, 2005 01:06 AM
Willie VTEC
Oct 29, 2003 06:50 PM
