Harness Bar/Roll Bar/5pt harness 93 del sol
Old Jun 27, 2011 | 06:06 AM
MadCoder's Avatar
Default Harness Bar/Roll Bar/5pt harness 93 del sol
Hi All,
I've been reading a lot on what would be a good safety upgrade for my weekend warrior street Del Sol and at the same time keep a semi-clean interior look.
Here is my current plan:
- Roll bar
- 5pt harness
- Seats with 5pt setup
- Harness bar (if I can't use roll bar)
- Stock SRS wheel
Can I attach the 5pt harness straps to a Roll bar? Or would I need a roll bar and harness bar?
Also, what kind of shop can properly install this equipment? Jiffy Lube?
If I'm missing something, please let me know
Thanks
Old Jun 28, 2011 | 05:55 AM
MadCoder's Avatar
Default Re: Harness Bar/Roll Bar/5pt harness 93 del sol
bump
Old Jun 28, 2011 | 07:30 AM
Red_Army's Avatar
harness and roll bars if they aren't welded in place will break.
you need a roll cage at least.
otherwise your stock setup with airbags will save you all the same. i've been hit head on by a semi goin 50 and airbags saved me. i think any race you do will be fine.
is that a serious question with the shop? a quick lube place?
search more.
Old Jun 28, 2011 | 04:45 PM
MadCoder's Avatar
search more.
Wow. That's quite the hit.
I've read going the roll cage route with a street car was dangerous and would require a helmet.
I'm serious about the question, but the jiffy lube part was a joke
Old Jun 29, 2011 | 12:30 AM
NotAJDMFanBoy's Avatar
No idea on the cage/bar issue, I just know that if you get harnesses, get DOT approved ones unless you plan to wear the OEM belt while on the street.
Old Jun 30, 2011 | 06:18 AM
MadCoder's Avatar
bump
Old Jul 1, 2011 | 06:39 AM
MadCoder's Avatar
bump
DailyDriven259
May 31, 2015 07:05 PM
thermal
Welding / Fabrication
21
Jun 17, 2006 08:39 PM
BrianDelSol
15
Oct 29, 2004 05:20 AM
alpalwal
Aug 27, 2004 03:27 PM
Powered by Honda
15
Mar 5, 2004 06:54 AM
