Harness Bar/Roll Bar/5pt harness 93 del sol
Hi All,
I've been reading a lot on what would be a good safety upgrade for my weekend warrior street Del Sol and at the same time keep a semi-clean interior look.
Here is my current plan:
- Roll bar
- 5pt harness
- Seats with 5pt setup
- Harness bar (if I can't use roll bar)
- Stock SRS wheel
Can I attach the 5pt harness straps to a Roll bar? Or would I need a roll bar and harness bar?
Also, what kind of shop can properly install this equipment? Jiffy Lube?
If I'm missing something, please let me know
Thanks
- Roll bar
- 5pt harness
- Stock SRS wheel
Thanks
Re: Harness Bar/Roll Bar/5pt harness 93 del sol
harness and roll bars if they aren't welded in place will break.
you need a roll cage at least.
otherwise your stock setup with airbags will save you all the same. i've been hit head on by a semi goin 50 and airbags saved me. i think any race you do will be fine.
is that a serious question with the shop? a quick lube place?
search more.
search more.
search more.
search more.
I've read going the roll cage route with a street car was dangerous and would require a helmet.
I'm serious about the question, but the jiffy lube part was a joke
No idea on the cage/bar issue, I just know that if you get harnesses, get DOT approved ones unless you plan to wear the OEM belt while on the street.
BrianDelSol
15
10-29-2004 05:20 AM
Powered by Honda
15
03-05-2004 06:54 AM
