is 16ga stainless possible with a stick?
Old Jun 26, 2011 | 11:55 PM
racebum's Avatar
Default is 16ga stainless possible with a stick?
figured i'd ask before i buy some scrap tube to experiment. i have a downpipe that needs to be sized on the car to finish, just no way to fit it and run down the street to tig UNLESS i use my trusty lincoln ac225. so, the question is
1. should i attempt to do complete welds with 308 or 309 rods
or
2. tack it with the stick and run down the street to my fab master neighbor with the syncrowave
this seem like a silly question? it probably is, i just haven't ever tried to stick stainless before. weld strength is the other concern
Old Jun 27, 2011 | 12:30 AM
SlowReaction's Avatar
Default Re: is 16ga stainless possible with a stick?
Line it up, use sharpy to mark the position of the tubes and then bring it to him to tack?
Old Jun 27, 2011 | 03:12 PM
rndmheroxx's Avatar
you can do it! i have that exact welder, and did the same thing. i use 309 rod, although 308 should be fine too, amperage set at 75amps, its not as bad as you would think. i really dont even feel like had to move that fast either.
Old Jun 28, 2011 | 12:37 AM
RickyLee53's Avatar
Probably would work, however the person welding won't thank you for it.
Prep is 90% of the job, when people bring there own jobs in i'm never happy with the prep so the welding ends up costing more and the job isn't as good.
Old Jun 28, 2011 | 01:00 AM
EJAYATE's Avatar
I Deliver
I cut a stainless bmw muffler in half, changed some of the baffles and welded it back together. Worked perfect and didn't look half bad either.
If you tack it just make sure the flux is cleaned off before tig welding it.
Old Jun 28, 2011 | 06:38 AM
that-guy's Avatar
i would say cut/shape the DP as needed on the car. use tape to hold the pieces together to make sure everything is where you want it. use a scribe to mark the pieces going together in 3 places around the seam, and add a number or letter to each piece to signify which piece goes where, that way the guy welding it will know what goes where so it doesn't get screwed up. as others said, prep is 90% of the job. if you throw some tacks on it, he is going to have to take it back apart and clean it to ensure that where the tack was isn't a weak point. so just mark it up as needed, and give it to him to do all of the welding
Old Jun 28, 2011 | 10:15 AM
MR.johnson's Avatar
x2
its always a pain in the *** to prep.
Old Jun 28, 2011 | 01:37 PM
racebum's Avatar
it's all brand new metal. i'll see how it goes with the tape and sharpie, only tack if necessary. if i do i'll give that a go with 75 amps and 309 rod
KtHaNxBai
May 25, 2012 07:32 AM
9295EJ-t
Welding / Fabrication
10
May 10, 2010 06:39 AM
kyden
Jan 16, 2008 06:10 AM
TurboEM1
22
May 6, 2007 11:06 AM
Atheist
Sep 30, 2004 04:03 PM
