fuel injector wiring
anybody have a wiring diagram for an si harness? tucking wires on b16 and removed all injector clips from harness, now not sure which colors go to which injectors
have red/red, brown/red, yellow/red, and grey/red. thanks
to answer your question, starting at the dizzy side injector it should be wired
1 red/blk+yellow 2 red/blk+grey 3 red/blk+red 4 red/blk+brown
i know what wire colors mean. what i was getting at is if the wiring was stock or modified? and you have it backwards, injector #1 is closest to timing belt. it also matters if the car was originally a DX, STD or SI (HF if CRX). this will all play a big role in how your harness was originally wired into the stock shock tower plug.
^^^ CRX SI-R build harnesses for $$$ - I would listen to him before the other guy.
OP you need to state a little more information about the car and the wiring setup.
thanks everybody for your help time to get finishd tucking xD
