jdm itr vs usdm itr pulley the same size?
Old Jun 26, 2011 | 01:16 PM
maxogsr's Avatar
Default jdm itr vs usdm itr pulley the same size?
I'm serching for more than 1 hour but could'n find the answer... I use to have a built gsr but I just swap a jdm specR and now my alternator belt is not the good size anymore... Now my question is: are jdm and usdm itr crank pulley the same size? I need to order the right belt...
thanks!
Old Jun 26, 2011 | 01:21 PM
CW-ITR's Avatar
Default Re: jdm itr vs usdm itr pulley the same size?
Yes, both are the same size.
Old Jun 26, 2011 | 02:19 PM
racebum's Avatar
you see the usdm b18c5 used a gold plated crank pully that God himself created, thus the reason for the misfit
yea...anyway
they are exactly the same and if you're having an alternator fit problem one of a couple things is the problem.
1. you aren't tensioning the alternator correctly
2. you picked up the wrong belt
3. your gsr had something non stock on it
a gsr and itr are 100% compatible with alternators, belts and crank pulleys
Old Jun 30, 2011 | 02:56 PM
maxogsr's Avatar
thankS
Dekorum
Aug 31, 2016 05:17 PM
'00_GSR/R
Jan 25, 2009 11:41 PM
Muckman
Apr 28, 2007 06:59 AM
DeDonDeRosa
Jun 29, 2004 04:11 PM
