91 civic timing
Old Jun 25, 2011 | 05:47 PM
Wiretaju's Avatar
Default 91 civic timing
hey honda-tech, i am at that point where i am in need of changing my timing belt on my EF hatch, does anyone know the porcedures to doing a timing belt job?? my motor is a d15b2 btw thanks everyone
Old Jun 25, 2011 | 06:49 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 91 civic timing
Yes, but your best bet is to buy a manual. You can get them for around $20 and it will be your best investment you can make for you and your car. Read the steps 5 times over and then dive in. Be sure you have all the tools/ specialty tools needed as well before you start (like a torque wrench for example).
Old Jun 26, 2011 | 04:40 AM
1990edsedan's Avatar
Or one could use the search function and get the instructions and get the manual for gratis...
Make sure you get the right manual, as there are differences in timing d15b2 and d16a6 and the sohc zc.
Old Jun 26, 2011 | 11:15 AM
EKwreckRLS's Avatar
You either need a specialty tool to hold the crank pulley still (you can sometimes rent these) or you need access to air tools to zap the crank pulley bolt off.
Other than that what everyone else said, torque wrench and manual are the most important tools.
Old Jun 26, 2011 | 04:02 PM
netfreak's Avatar
I used an electric impact on the crank pulley and whiteout to make a few marks on the old belt so I knew the tooth count on each side.
BoaConstrictor
13
Oct 26, 2015 10:09 PM
raffaelli
Sep 2, 2013 07:10 PM
jodyboy
10
Jun 29, 2012 05:47 PM
Randysi
12
Oct 20, 2011 03:00 AM
patentguy
Feb 2, 2006 12:03 PM
