Tires messing up ... Camber off ...
So i have a 94 accord ex and i took it to the shop for an alignment and they adjusted my camber in the rear
and now my car is going thru new tires in like 2 months/ used tires in 2 wks and blowing
... how can i adjust my castor so that my camber isn't negative
... if possible can you add pics, im pretty good around cars so im hoping it'll be easy
... I think he adjusted it to the honda specs, but its not lowered and has the stock rims ... I know it was in a accident before i owned it so that might be why it wasnt right when they adjusted it ...
They got aligned at the shop but i dont think he adjusted the toe ive been reading up on it and they said the camber wouldnt eat the tires that much the toe will ... its only the inside rear thats going super fast the fronts are ok ... i need to find out how to adjust the toe because its positive ... he said he adjusted that camber and everything to the honda specs ... but i know he didnt do the toe because i dont remember seeing him adjusting the rear control arm bolt ...
Post your spec sheet so we can help you further.
cilvia
Mar 23, 2011 05:28 PM
