Can i use OBD2 Gsr ECU with OBD1 Gsr Motor?
i have a OBD1 gsr motor in my Civic si...im wondering if i can use a OBD2 Gsr ecu so i wont have to use a stepdown harness and use the OBD1 P72
Please let me know if this is possible. i do know that it will look for a crank sensor which i dont have so i know the CEL will be on so thats ok.
Thanks in advance fellow members!
so then only the CKF trick is needed ? if i dont do the trick will anything be wrong or perform differently or will i just have the CEL on the dash showing and thats it ?
as far as performance from obd1 and obd2 i believe they run the same
if any other info let me know guys thanks
strictly.business
Nov 25, 2006 09:05 PM
crxhybrid85
Mar 15, 2005 08:50 PM
