92 acura integra doesn't want to go
the car will start then stall out. i have to rev the engine to about 3 or 4 rpm's then let out the clutch just to get rolling but if i dont put the clutch back in it will rev down an shut off.All so when you push the gas pedal in the car act's like it want's to shut off but rev's up as you'r letting up off the gas.was told catalytic converter was clogged so we cut it off an put straight pipe in.changed the spark plugs,wire's,fuel filter, and distributor cap.was going to change rotor button but screw was stripped.plz help been down for two weeks now and running out of money.any info i could get on what to do next or what it mite be would help out a lot.thanks.
ok i did a diagnostic and the codes that came up were/1/43 which is oxygen content and fuel supply system.now since the o2 sensor is implied in both should i go ahead and change the o2 sensor? any help would be nice since no one has responded yet.
thanks to all 115 that just looked and not give any help..I new this was a joke of a site but i thought i would give it a try and guess what....the jokes on me hahahahahahaha........again thanks for all the help!!!
yeah it take some time to answer but it sound like u are having a IAC (idle air control)problem. its very common with integra its like if your drive press the gas its fine but as soon as u slow down and let go of the gas its almost die or it does die if its really bad.. did you first start to notice that the rpm drop below 1k and want to die. but didnt.. not now it does?
well when your going down the road at about 45 to 50 now it starts to bog down.when you hit the gas the rpm's would die down and when you let up of the gas at a certain point the rpm's would shoot back up the back down. i just got done changing out the fuel pressure regulator. it start's up better but is still doing the same on the road.
5 Skware
Sep 12, 2003 07:05 PM
