Can i flash or take out the governor?
Old Jun 24, 2011 | 12:24 AM
Jader714's Avatar
Default Can i flash or take out the governor?
If i flash, or take out the governor, will my mpg increase?
if so, how much and what else will i get?
i have a 99 civic ek d16 all stock.
Old Jun 24, 2011 | 12:55 AM
b18c5_ej8's Avatar
Default Re: Can i flash or take out the governor?
get a obd1 jumper harness and chipped p28 you can get basemap with no governor
Old Jun 24, 2011 | 01:00 AM
NOFX's Avatar
H-T White Ops
I don't see how not having a speed governor would increase your fuel economy.
Old Jun 24, 2011 | 01:01 AM
Jader714's Avatar
is it plug and play, or will i need to tune it?
Old Jun 24, 2011 | 02:37 AM
grumblemarc's Avatar
The Grumpiest
This.
Old Jun 24, 2011 | 06:47 AM
apexi_rsx's Avatar
first off the car doesn't have a governor and second the car does not have enough power to push past 120 and third the this will not increase fuel economy in anyway.
Old Jun 24, 2011 | 07:15 AM
NACvicSi's Avatar
What do you think the rev/speed limiter is? It's nothing but an electronic governor.
Old Jun 24, 2011 | 07:29 AM
Jdm03's Avatar
First of all, this is America!! Not Europe that you can max out in the highway..
second and most important, if you're doing auto x racing or drag racing, aint no where in hell you'll succeed reaching top speed in a STOCK motor. period!
Old Jun 24, 2011 | 08:10 AM
Arthas's Avatar
Since hes gonna be doing 140mph on the highway, hell get to his destination faster and use less fuel.
/sarcasm
Old Jun 24, 2011 | 08:28 AM
Libertariat's Avatar
Ek Forever y0!
So much wrong... don't.. know where... to start...
must.. tear out... eyeballs..
Old Jun 24, 2011 | 08:44 AM
that_boy_sammy's Avatar
Not on a stock motor.
Old Jun 24, 2011 | 08:57 AM
The Seller's Avatar
/sarcasm
Just made my day
Old Jun 24, 2011 | 08:48 PM
Jader714's Avatar
im new to the car scene. I heard, if you take the govenor out or flash it you can get better mpg. i dont plane on going 120mph anytime soon not even 100.
Old Jun 24, 2011 | 09:55 PM
Ek Forever y0!
1st, there is no governor. 2nd, what would you change to increase fuel mileage? You don't think the hundreds of engineers made hondas as efficient as they reasonably could? 3rd, how much more fuel efficient would you car be? 1? 2 mpg?
Old Jun 24, 2011 | 11:13 PM
Red_Army's Avatar
what has been seen.
seem pretty new to the whole automobile idea to me...
Old Jun 25, 2011 | 08:04 AM
NotAJDMFanBoy's Avatar
The car is not governed. The engine has a rev limiter, but you will not hit it in 5th gear with a stock motor.
If you modify car, like throw a turbocharged GSR swap in, then you'd have to tune it anyway and you can remove the rev limiter then...though it's not a good idea.
Old Jun 25, 2011 | 10:24 AM
Jader714's Avatar
what about a intake?
Old Jun 25, 2011 | 11:38 AM
Wrona's Avatar
what in the hell are you talking about if ur MPG is crappy than do a full tune up.... Cap, Rotor, Plugs, Plug Wires, PCV valve, Clean the IACV, New Air filter oil w/ filter, and Fuel filter i also add BG44k every 10k miles
Old Jun 25, 2011 | 01:02 PM
Arthas's Avatar
Dont. Ever. Touch. A. Tool set.
Old Jun 25, 2011 | 01:03 PM
Jader714's Avatar
already did most of that
Old Jun 25, 2011 | 01:07 PM
Arthas's Avatar
Then your car should be running like a boss and thats about the most you can do to get some serious MPG's out of it.
Old Jun 25, 2011 | 01:08 PM
Jader714's Avatar
ok thx for the info guys
Old Jun 25, 2011 | 08:21 PM
Ek Forever y0!
Don't do anything to your d-series unless you rebuild the entire thing with high compression pistons and some solid cams.
Or you turbo it.
Anything else is a total waste.
Old Jun 25, 2011 | 08:24 PM
Arthas's Avatar
Most people that I hear do N/A builds on their D regret it afterwards. The end results are not impressive.
BOOOOOOOOSTED D FTW!!!
Old Jun 25, 2011 | 09:15 PM
Ek Forever y0!
For the cost of a gsr swap you can make similar power with a naturally aspirated d-series, that is if you're buying it from a motor importer and not snagging deals on local parts.
N/a d-series isn't bad if you're comfortable with ~150-160whp and 115tq.
It's fun, quick, easy, cheap replacement motors.
For the same money you could easily make 250whp on a d-series. Or the same power on a "fresh" gsr swap.
SoupEk
Sep 8, 2014 02:52 PM
boostin99em1
Jan 18, 2011 09:28 PM
erikiksaz1
Engine Management and Tuning
Nov 16, 2010 08:51 PM
foowitdaredek
17
Dec 17, 2007 10:13 AM
JDM00SI
Oct 31, 2005 01:54 PM
