What's the most you have made on a Single Walbro 255????
Old Jun 22, 2011 | 09:55 PM
Duende's Avatar
Default What's the most you have made on a Single Walbro 255????
Hey i been curious on how much the single Walbro 255 intank can hold...The most i made so far has been 510whp on Precision's 1000cc....Anyone else?
I'm about ready to hit the Dyno again with my built motor...I made 510 with my bone stock bottom end GSR...and i'm hoping for more now that i have my built motor
Would a relay help out alot??? if so what relay, thanks
Old Jun 22, 2011 | 10:19 PM
turbo-2nr's Avatar
Default Re: What's the most you have made on a Single Walbro 255????
iv seen a little over 700 but wouldent do it my self lol
Old Jun 22, 2011 | 10:51 PM
eg:R's Avatar
570-580whp on e85
Old Jun 23, 2011 | 03:14 AM
Boosted_B_Series's Avatar
Originally Posted by eg:R
570-580whp on e85
That would be a high reading dyno
Old Jun 23, 2011 | 03:48 AM
j-bird20's Avatar
Maybe i had a weak walbro but i was leaning out pretty bad at just under 550. Pressure was falling off pretty hard. Thats in a EF with stock lines. Dyno Dynamics Dyno.
Old Jun 23, 2011 | 05:16 AM
th3pwn3r's Avatar
I've been thinking of selling my Walhbro and getting a doucheworks 300lph in tank for a little more wiggle room. Hmmm...
Old Jun 23, 2011 | 05:57 AM
D-Rob's Avatar
570-580whp on e85
No, you didn't.
A single Walbro 255 realistically runs out in the 550whp neighborhood on gasoline.
Old Jun 23, 2011 | 06:03 AM
MR.johnson's Avatar
580hp. e85. h22.
Old Jun 23, 2011 | 06:09 AM
CDecker0218's Avatar
506whp, 23psi c16 last year on my brothers car
Old Jun 23, 2011 | 06:31 AM
Project_EK's Avatar
592whp walbro 255hp & ID1000's on c16 but maxed out pump and injectors at that point..
Old Jun 23, 2011 | 07:39 AM
Duende's Avatar
i been told 600 is possibly with a relay, as long as there is constant voltage???
Old Jun 23, 2011 | 08:03 AM
MR.johnson's Avatar
the 580 was at 13.7v.
Old Jun 23, 2011 | 08:05 AM
sgnlab's Avatar
I made 633whp with a single walbro not the best idea but I did it on race fuel..
Why bother though why not just get a single aeromotive 340lph pump???
Old Jun 23, 2011 | 08:30 AM
Duende's Avatar
i actually wasnt aware of that 1......whats the pontentioal on that 1?
Old Jun 23, 2011 | 08:35 AM
sanman000719's Avatar
more than the wally and as you see 550 is about the average max power the wally makes
Old Jun 23, 2011 | 09:34 AM
Poootie's Avatar
i made 552whp with room to play on the same dyno.. C16 , stock lines with stock fuel filter.
Old Jun 23, 2011 | 10:35 AM
TurboSpoolinInside's Avatar
I am only at 520 on e85 with a modded one and rewired. Plenty to go!
Old Jun 23, 2011 | 10:58 AM
Duende's Avatar
im thinking bigger wiring and a nice a relay
Old Jun 23, 2011 | 02:04 PM
nonvtecallmotor's Avatar
The Prelude made 670-680 on a single Walbro with a relay and 999cc MSD injecters.
Old Jun 23, 2011 | 02:21 PM
BoostR41's Avatar
583whp stock wiring and precision 1000's on sunoco 112 last year but I was 100% out of injector
PS- motor popped the end of last season so I don't recommend it unless you have 1200's
bryse68's Avatar
63*HP @ 26-27PSI on c16. rc 1000s@96%......with a b&m commandflo.......
Old Jun 23, 2011 | 02:23 PM
bryse68's Avatar
also with a bosch relay.
Old Jun 23, 2011 | 02:52 PM
Duende's Avatar
Can u check out my build threaad? And see if you I can even make over 600 with my setup
Old Jun 23, 2011 | 03:00 PM
v.i.gsr's Avatar
what size amp relay are you guys using... For the f/b dual pump setups are you guys using two relays or one...
Old Jun 23, 2011 | 05:43 PM
Duende's Avatar
im not sure thats why i'm taking advice
