1999 Honda Accord Ex v6
The tires that i have on it now are 205/r6016/91h and i found good deal on some tires from a 2003 Accord lx same bolt pattern but smaller size. It is 205/r6515/92h would it make that much of a diffence? I am fairly new to Honda's and would like some sound advice..The dealership said it should be fine because the have same rotors,ect,ect.. Thanks in advance for any input...
205/60/16 currently?
A 205/65/15 tire is not going to fit......the wheel is an inch smaller in diameter than your current set.
For the future the tire reading is as follows
width/sidewall height % of width/wheel diameter
I don't think you're grasping what I'm saying.
You cannot put 205/65/15 tires onto a 16" wheel. You physically cannot do it. The tire is 1" too small in diameter. You need a xxx/xx/16 tire to put on your 16" wheel.
If you are talking about a 15" WHEEL with a 205/65/15 TIRE that is 5x114.3 then that is a completely different story but is not what you asked.
You can use the following website to see that they will come out to be approximately identical in size.
http://www.miata.net/garage/tirecalc.html
In that case you should be fine - your speedometer will not be affected much at all.
Though 15's on a 6th gen may look too small - I'm guessing these are steelies with hubcaps?
STN_Pat
Oct 17, 2011 06:59 AM
