93 Accord will not start
Old Jun 22, 2011 | 06:22 PM
SteveL57's Avatar
Default 93 Accord will not start
1993 Honda accord will not start when warm. It will only start when its cold.
1993 honda accord 4 door sedan after starting and running until normal temp I can shut off 1 or 3 times until it won't start again. I have to wait until 45 minutes to an hour until it will restart then has same symptoms after it gets warm.
I have tried:
coil, module, cap, rotor, wires, plugs, fuel filter, fuel pump relay,
oms-ed out injector interrupter came out at 6.3 on all lines, checked all fuses, check battery and cables.
It is getting fire and fuel but still won’t start until its cooled down again.
Old Jun 22, 2011 | 06:36 PM
curtie94's Avatar
Default Re: 93 Accord will not start
If it is getting spark and fuel then make sure its getting air and also check for compression. First try to spray starting fluid in the throttle body if it starts then it isnt getting fuel.
Old Jun 22, 2011 | 08:59 PM
y_not's Avatar
i had the same problem a while back. i will just use starting fluid to get it started on hot days. found out the problem later. it was the fuel pump relay. hope this help out.
Old Jun 23, 2011 | 03:38 AM
justinsbg's Avatar
First determine what's missing from the equation: Spark, Fuel, Compression. If you're not getting fire look into your ICM (ignition control module) or the Ignition Coil. If you're not getting fuel turn the ignition switch to the "on" position and make sure you hear 2 clicks from the main relay. 1 click as soon as you turn the switch on and 2nd click 2 seconds after the switch is turned on. This indicates that the fuel pump is being enegized to pressurize the fuel rail in preperation for starting the vehicle. Let me know if you need any more info about these instructions.
Old Jun 23, 2011 | 07:10 PM
mutiny93's Avatar
sounds like a main relay. I don't know if that's what you mean by fuel pump relay. I had the same problem too just rest replaced my main relay. I have found out that the cheapest place to get them is O'Reilly Auto Parts. I hope that helps
Old Jun 23, 2011 | 07:46 PM
nus_dogg's Avatar
^^ x2!
Old Jun 23, 2011 | 09:12 PM
bzmotoninja1983's Avatar
i had an accord back in the day that you would have to turn the key a few times to "prime" the system. found out that the fuel strainer was like a brick. changed that and it ran like a demon.
also, had a friend with a del-sol. it would start when cold only to shut off after getting to normal opperating temps. it was the (dont know what to call it) black box inside the distributor...... it had a hairline crack and would expand just enough when it started to get hot
Bz
Old Jun 24, 2011 | 03:35 AM
justinsbg's Avatar
Again, determine what's missing. It's easy to start guessing what parts to throw at it. If you know what's missing (spark, fuel, compression) then you will save time and money. Sure there are common pattern failures on these cars, but try and diagnose properly. That's what distinguishes the good techs from the lazy. @bzmotoninja1983: I believe you're thinking of the ignition coil. He says he replaced the coil. I would look deeper into either the ICM or Main Relay. I can give you detailed ways to check either of them.
Old Jun 24, 2011 | 03:59 AM
Justinsbg, I don't think it was the coil. But, who am I to say what's what in a Honda? I'm just a redneck with a 4x4....lol. @OP, I agree with Justin, tossing part at it then freaking out because you have checked "everywhere" just means you missed one small detail. Good luck
Hunter62
Feb 13, 2018 09:51 PM
skinney6
Oct 17, 2012 09:58 PM
stsmike
Aug 18, 2012 11:12 PM
demian22
Nov 8, 2009 10:11 PM
frzr
Classic Hondas
Jan 15, 2008 09:57 PM
