Need Help: RS Prop Valve to 98+ GSR Master & Booster
Old Jun 22, 2011 | 02:01 PM
TypeSiR-G's Avatar
Icon2 Need Help: RS Prop Valve to 98+ GSR Master & Booster
Hey whats up H-T, I know there are some write ups on something similar but I couldnt find the specific answer. I know i can buy the 98+ Integra RS Prop Valve and brake lines so that it would work with the 98+ Integra GSR Master & Booster that I just bought, but I already have the 95 RS Prop Valve and i was wondering how i can fit this to the 98 Master/Booster that I just picked up.
Is there a place that sells flexible lines or custom bent lines that go from the Prop Valve to the Brake Master/Booster? I saw that rywire.com has a prop valve relocation kit but that thing is $400! I dont want to spen that much so if any of you can tell me what I can do, I would greatly appreciate it!
Also if I decide to buy the 98-01 Integra RS hard Brake Lines and the Prop Vavle, does anyone know if this would be a direct bolt on fit on my 1995 Integra GSR? (I know the 98-01 ABS brake lines won't fint on a 94-97 GSR because the back brakes have their separate individual lines on a 98-01 Integra, so what about the RS brake lines?)
Thanks for the help!!
Old Jun 22, 2011 | 02:41 PM
TypeSiR-G's Avatar
Default Re: Need Help: RS Prop Valve to 98+ GSR Master & Booster
Bump
Old Jun 22, 2011 | 03:24 PM
94rs-turbo's Avatar
98 RS LINES AND PROP ARE DIRECT FOR WITH 98 MASTER, SEEN STEEL BRAIDED LINES FOR MASTER TO PROB BEFORE FOR LIKE 50'ISH
Old Jun 22, 2011 | 04:22 PM
TypeSiR-G's Avatar
Thanks for the reply! But i was reading up and I dont think the 98+ Prop Valve and Lines will fit my 95 Integra GSR because the 98-01 Integras have separate individual lines for the back brakes as oppose to the 94-97 Integras which have one line going back to the back brakes. Is this correct? If so, what can I do to connect 95 Integra RS brake lines to a 98-01 Master Cylinder?
Thanks again.
Old Jun 22, 2011 | 04:23 PM
TypeSiR-G's Avatar
Bump
TypeSiR-G
Jun 27, 2011 08:00 PM
swallow
11
Aug 7, 2010 09:14 PM
bmwe362006
Jan 13, 2010 06:37 PM
RuffRhyno
Sep 25, 2003 05:53 AM
92B20GSR
Sep 21, 2003 09:19 PM
