B16 Valve seal replacement...
Old Jun 22, 2011 | 07:23 AM
HellaFab's Avatar
Default B16 Valve seal replacement...
If a B16 valve seal was leaking, would replacing just the valve seal solve the problem, or would this generally require new valve guides and a mild polish of the valve to ensure that it doesnt leak?
My EM1 head has 230,000km and I would like to do some preventative maintenance on it. There is mild oil consumtion at VTEC crossover that I would like to fix.
Please dont regard this as a "all VTEC engines do this"
Matt
Old Jun 22, 2011 | 08:15 AM
Atomic1's Avatar
Default Re: B16 Valve seal replacement...
At that mileage, it really could be worn valve guides. If that's the case, new valve stem seals will go bad quickly.
At that mileage I would probably pull the head and have it sent to a shop so they could check the clearances and do a valve job.
If you're tight on cash you could just replace the seals yourself without pulling the head and see if the problem comes back. If it does, then you know you probably have to get new guides. The seals aren't very expensive.
And yes, every VTEC engine I've seen consumes oil. Whether or not you're pulling oil through the stem seals is another question. How do you know that this is the problem? Blue poof at startup?
Old Jun 22, 2011 | 08:55 AM
HellaFab's Avatar
Is there a max spec for the valve to guide that i could possibly check with a dail guage?
Matt
Old Jun 26, 2011 | 09:19 AM
Atomic1's Avatar
Nope, machine shop is really the only way.
Old Jun 28, 2011 | 07:37 AM
jhar_ek's Avatar
there are specs for the valve guides...just have to find them
Atomic1
Mar 27, 2010 08:57 PM
si937
Jul 25, 2006 02:18 PM
SYN4DRDX
Jul 9, 2005 12:09 PM
jdmlsvtecrx
Sep 20, 2003 05:02 PM
sporkcrx
Jun 15, 2003 08:41 PM
