1994 integra no power hard idle after head swap
well the car was lsvtec. we switched back to ls head because it was burning leaking oil.
the head was prepped and cleaned. new intake manifold gasket and throttle body gasket.
well after the swap the car would not start. it finally started. but idle was very very low. this head was the original head on the car and it ran great. the car is running a p75 ecu. all obdI
it only started wot and it would not rev at all. it was steady 600rpm even at wot.
later it idled but very low like 200 below the line. i could slowly give it gas and it would go higher. than after 3000rpm is revved fine. cannot drive it at all though. will not start unless i have the pedal to the floor. then slowly starts and idles at 700 with the pedal down
the car has no cels.
its a big headache i cant figure out whats wrong
timing was checked. ill recheck it. spark is good. compression is good. fuel is good. and no cels
nope checked those. i never get plugs switched. i label everything. and i know tps has the red wire in the middle/ map never does
yep the timing is dead on. i just redid it 2 minutes ago.
the car will not even attempt to crank. its not a hack job either. all wiring is stock. no extra wires or any bs.
changed spark plugs checked injector plugs, rechecked tps/map. i dont know what else to check now. i hear fuel pump priming
have not ran compression. test. but already did valve adjustment on it after i swapped it in.
ill check compression but im not thinking its that. the motor sounds like it has good compression by the way it turns and i can hear it
Hqve you checked your ignition timing?is it installed correctly?spark plugs and wires too
spark plugs were changed no difference. wires seem to be good since the car was running with the same plugs and wires
Well the car starts or not?i read that "no power idles hard" how do you know that if i doesnt start?just put the ignition on the midle ,im just trying to help you
Ps what ecu are you running?are you running chrome?
They meant mechanical timing of the crank and head. If that is off by a tooth or 2 it will cause hard starting and mushy acceleration that you described. Trying to adjust distributor timing if the mechanical timing is off wont fix the initial problem.
ecu was switched for lsvtec. this ecu in it now is a stock ls one matched to the motor. there is no vtec
now the timing is set perfect. im not new to this. the white mark seprate from the 3 other marks is tdc and that is how it is set
Well the obvius is that the timming is wrong but whe have to assume is set right cause whe arent there, do you have adj cam gears?also i will try the other ecu just to check you dont loose anything to try
motor is bonestock. no cam gears nothing. only thing aftermarket is golden eagle oil seal and intake
elmejor
Jul 23, 2009 07:08 PM
taimysho0
Feb 7, 2009 04:01 PM
