Bad pressure plate???
Was mashin through gears like an idiot now can't put it in gear while car is on but only when it's off, clutch still has normal pressure and fluid is full....then when I started it in gear to get home it def didn't like that
because it goes into gear when the flywheel is not turning (engine off) it's going to be a problem with either the clutch or pressure plate for sure. regardless, transmission needs to be pulled to diagnose/repair
erikiksaz1
Jun 10, 2007 10:38 AM
