Lowered my CRX today.
This is how it looked when I bought the car.
The parts:
ST full body coilovers.
ST Front Sway bar w/new sway bar bushings
ST Rear Sway bar w/new bushings.
New upper A-Arms
New upper ball joints
New Lower ball joints
New inner tie rods
New outer tie rods
1/2 way there:
All Done.
Final drop was a little over 3.5 inches.
The parts:
New upper A-Arms
New inner tie rods
New outer tie rods
1/2 way there:
All Done.
You missed a bunch of pictures of the parts installed and wheels still removed!
and the drop is too low IMO, I'm not a fan of the tucked look, just a nice even gap all the way around looks best.
and I don't like the all white look, and the tint, and the color of the wheels.
haha, just my opinion though, take it with a grain.
exhibit a:
exhibit a:
Here is the list of what we've done so far.
rebuilt head with all new seals, valves, valves springs, and guides.
new oil pump
new water pump
new spark plugs
new radiator
(2) 12" electric fans. (replacing the stock fans)
new A/C condenser
new A/C dryer
new A/C compressor
new A/C hosing
Changed oil
oil filter
air filter
fuel filter
HID 5K lights in low-beam location.
HID 5K lights in high-beam location.
suspension work
new lower ball joints.
new upper ball joints
new inner tie rod ends
new outer tie rod ends
new upper A-Arms
new ST Rear Sway bar w/new bushings.
new ST Front Sway bar w/new sway bar bushings
installed new rear lower control arm bushings
Brakes:
new brake booster
new master cylinder
new brake rotors front and rear
new brake pads front and rear
Completely stripped the car and put back together and laid:
108sq^in of Stinger's Roadkill Expert Series.
24^ft of Stinger's Roadkill Overkill Foam Damping Mat.
24sq^ft of Stinger's Roadkill Foam Damping Mat.
This car is EXTREMELY quiet going down the road at 80mph.
Installed RFID Keyless system
installed Lexus Push to start button in factory key location
Removed the sunroof and sealed it up. (More headroom)
Installed power windows
Installed window switches flush in drivers door.
Installed power door locks
Installed power trunk pop
Installed 2-way Compustar Alarm w/Remote Start
Installed DEI Window rollup/down module.
Wrapped headliner in Suede
voltage gauge in the factory clock location
Stereo system:
Headunit:
Apple iPad (digital out)
Processor:
Audison BitOne
Front Stage:
-Audison VOCE 6.5" drivers in doors
-Audison VOCE 3.0" mids in dash pod on-axis
-Audison VOCE 1.125" tweeter in dash pod on-axis
Subwoofer::
Audison VOCE 12" at SQ comps
2 Digital Design 1508 SC subs for the daily application.
Amplifiers:
Audison SR4 mid/tweet
Audison SR4 (bridged) driver
Audison SR1Dk sub
Batteries:
(1) Shuriken BT-100
Relocated battery from front to rear
Wire:
Audison Connection RCA's, Power Wire, Speaker Wire, etc.
Ran two sets of 3/0 wire. One power, one ground.
We had to take the doors off to run wires through the boot. Normally we wouldn't have to pull the doors. But in this car, 8 12ga wires
new oil pump
new water pump
new spark plugs
new radiator
new A/C condenser
new A/C dryer
new A/C compressor
new A/C hosing
Changed oil
oil filter
air filter
fuel filter
suspension work
new upper A-Arms
Brakes:
new brake booster
new master cylinder
Stereo system:
Headunit:
Processor:
Audison BitOne
Front Stage:
Subwoofer::
Amplifiers:
Audison SR1Dk sub
Batteries:
(1) Shuriken BT-100
Wire:
exhibit a:
exhibit a:
The large majority of your wear will come from the toe out caused by lowering the car. set it to zero and you won't need to waste the money on a camber kit. If you're not driving the car much, avoid the extra costs. The car will more than likely corner better with negative camber.
enjoy!
enjoy!
enjoy!
enjoy!
