Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
what kind ATF transmission fluid for 2003 civic
Old Jun 20, 2011 | 07:00 PM
Jaydeep's Avatar
Default what kind ATF transmission fluid for 2003 civic
I don't want to buy transmission fluid from dealership. What kind ATF fluid we can use? Did anyone here try using other fluid and had no problem?
Thanks
Old Jun 20, 2011 | 07:42 PM
toyomatt84's Avatar
Sanji
Default Re: what kind ATF transmission fluid for 2003 civic
Honda ATF Z-1 can be purchased online for cheaper then at the dealership. I wouldn't recommend straying from the OEM fluid, as it can cause issues.
Old Jun 20, 2011 | 09:36 PM
MindBomber's Avatar
I second what, Matt stated. Honda automatics are very picky about fluids, so anything but OEM is a risk on an already delicate transmission.
Old Jun 21, 2011 | 05:00 AM
MarkM01's Avatar
Where can it be purchased online cheaper, plus shipping?
Old Jun 21, 2011 | 06:49 AM
toyomatt84's Avatar
Sanji
Most of the links that are at the bottom of the FAQ's will work.
Here's one for an example:
http://www.handa-accessories.com/civmaint01.html
Old Jun 21, 2011 | 07:54 AM
MarkM01's Avatar
Z1 is not listed, and I believe no longer made.
DW1 is now recommended by Honda for previous Z1 applications.
Shipping still seems like it takes the price right up to local dealer prices, or over if you only need a few quarts.
Old Jun 21, 2011 | 07:58 AM
slomofo's Avatar
GDD Member
I bought a case of Z1 from the dealer just yesterday. You sure it's discontinued? Maybe I just got leftovers or something.
Old Jun 21, 2011 | 08:08 AM
MarkM01's Avatar
No, I'm not 100% sure. I read it over on bobistheoilguy.com
Old Jun 21, 2011 | 10:18 AM
toyomatt84's Avatar
Sanji
DW1 is better fluid, to be honest, as it handles a bit more strain then the Z1 fluid.
Old Jun 21, 2011 | 12:14 PM
Fuzbal's Avatar
oh ya? but DW1 is a lot thinner.
I picked up 9 bottles just now.
Old Jun 21, 2011 | 12:45 PM
toyomatt84's Avatar
Sanji
Its far more heat resistant, from what I have read.
Old Jun 21, 2011 | 04:01 PM
MarkM01's Avatar
How do you know it's thinner? From analysis?
DW1 is said to be synthetic, Z1 was not.
Old Jun 21, 2011 | 07:37 PM
slomofo's Avatar
GDD Member
Maybe it's thinner to the touch, like the way you can tell that 20w50 is thinner than 5w30 just by touching it.
I hope it's not thinner though. I always assumed that Honda transmissions went bad quicker than any other car out there because their thin fluid breaks down a lot quicker, but that's just a guess.
Old Jun 23, 2011 | 12:33 PM
Fuzbal's Avatar
Gearbox on civicforums isnt a fan of the new DW1 fluid and says it will be worse for the Honda trannys over time than Z1 because its thinner and will be even thinner when used in hot weather making the wear on the gears faster because fluid wont be able to stay in between the gears.
Heres a video comparing
http://www.youtube.com/watch?v=x4Pw4fwnMDY
mrhuhes1023
Mar 13, 2018 06:12 PM
W95civicEXcoupe
17
Apr 14, 2015 06:11 AM
ManInBlack
Honda Civic (2006 - 2015)
Jul 15, 2013 03:04 PM
DennisWaller
Transmission & Drivetrain
Jul 26, 2009 09:41 PM
tom48
Jul 14, 2008 08:30 PM
