getting new rims soon what offset
Old Jun 20, 2011 | 05:05 PM
Jdmintegr's Avatar
Icon2 getting new rims soon what offset
ok so i get a new part for my car every pay check and its come to the point where all i need is suspension and rims, well actually just rims now just purchased progress suspension but i was wondering if running a 10 offset on my 95 dc would i have any issue on rubbing? my buddy runs infinit wheels and he says that the integra will fit 10 offset no problem without rolling fenders but ive seen many post with people running into issue with low offset wheels and tire issue. i know my buddy is running a 205/40/r16 on a 16x9.5 with a +0 offset but i dont wanna look cholo on my dc2 i just want to know whats the lowest offset i can go without looking cholo and stretching tires and not running into rubbing issues. thanks
Old Jun 20, 2011 | 05:06 PM
Jdmintegr's Avatar
Default Re: getting new rims soon what offset
pictures too i u have any
Old Jun 20, 2011 | 05:08 PM
Jdmintegr's Avatar
my buddys setup
Old Jun 20, 2011 | 06:38 PM
GagnarTheUnruly's Avatar
205 on 9.5" wheels is ridiculously unsafe and totally inappropriate in a 10 offset. But it's also an example of how far people can go out of bounds of what's reasonable and still have a car that's "driveable."
I've got 195/55/15's on 38+ 15x7's and I wouldn't go any lower offset, but not because I'm close to rubbing. Suspension control is better with the wheels closer to the arms so if you care about performance (and looks, IMO), that's about the range you should be looking at. FWIW my setup is already wider than stock.
Old Jun 21, 2011 | 12:03 AM
theEGGmonsta's Avatar
16x7 +40 with 205/45/16 is pretty common easy to run
i ran mine without rolling, no rubbing
16x7+40mm offset and im running falken ziex 205/50/16 on the integra, and my friend with the ek is running the same wheels but with 205/40/16; also no rub
my newer setup with 17x7.5 +35mm with 205/40/17, no rubbing either
same setup but with 25mm spacers, so it puts me at 17x7.5 +10mm
Old Jun 21, 2011 | 04:59 AM
Jdmintegr's Avatar
hmmm interesting
Old Jun 21, 2011 | 04:31 PM
Jdmintegr's Avatar
ok the tires arnt an issue but will a 10 offset clear no prob? or am i gonna have to roll the fenders
Old Jun 21, 2011 | 04:54 PM
TunerN00b's Avatar
Without also giving the wheel width, the offset is useless in trying to figure out if fender rolling will be required.
Old Jun 21, 2011 | 05:52 PM
yeah we need offset and width of the rim, but if it any wider than 7inch imma say you need to roll
Old Jun 22, 2011 | 01:00 PM
Jdmintegr's Avatar
i was planning on going with a 10 offset on 16x8
Old Jun 22, 2011 | 01:23 PM
you need to roll for sure mannn
Old Jun 22, 2011 | 02:16 PM
TunerN00b's Avatar
You'd be much better off with a 7" or 7.5" wide wheel. Much, much better tire selection that way.
But yeah, a +10 offset 16x8 isn't an appropriate wheel for a FWD Honda. Rolled and pulled fenders, and possibly added camber, will be needed.
Old Jun 22, 2011 | 04:42 PM
Jdmintegr's Avatar
FML! yeah i dont wanna look hood riding on those slammed hondas and stretched tires, not hating on that style but i do wanna go with the lowest offset i can without tire stretch and rub hmm what to do what to do!
Old Jun 22, 2011 | 05:01 PM
TunerN00b's Avatar
I think you might need to look up how offset and width affect each other.
A 16x7 +10 and a 16x8 +23 both put the outer lip the exact* same distance from the side of the car (* because I'm rounding off 0.5mm).
"Lowest offset" is a terrible goal. A 16x5 can be run with a negative offset and not stick out past the fender. The wider the wheel, the higher the offset needs to be to not "poke" out past the fender.
If you don't want tire stretch, you really want a 7.5" wheel at the widest. 8" wheels will mandate a 215/45-16 tire. A 7.5" allows either 215/45-16 or 205/45-16 and most tires only come in one or the other size, increasing tire availability significantly.
As for "what to do", first and foremost decide if you'll willing to limit tire sizes or not, so you can decide how wide of a wheel you can run (I'd seriously recommend staying at 7.5" or 7"). From there, you find a wheel in the correct width that gets you close to flush, and use a spacer to make up the small difference left. You can go up to 5mm on a spacer with stock studs. Go measure on your car how much clearance you have between now and the exact amount of "flushness" you want, and calculate backwards to determine the offset needed to achieve that.
Old Jun 22, 2011 | 05:52 PM
Do you want low offset just so you can impress your friends? If so get 6" wheels with negative offset and have them fawn all over you. If you want the tire to have a certain relationship to the fender then determine what that relationship is using the information TunerNoob gave you.
People will be able to help you better if you have a specific question. For example if you have X in. drop on Y lb/ft springs what is the lowest offset 7" wheel you can run with 205/45-16 tires without running into problems with rubbing.
FadeToBlack
Sep 6, 2005 06:03 PM
KRWOO79
Acura TSX
Jun 13, 2005 08:44 AM
jeremy.
Jun 20, 2004 10:28 AM
OEMedUP
Acura TL, RL & ZDX
Apr 25, 2004 04:44 PM
avs
Jun 11, 2003 09:19 PM
