92 Acura Integra starts up but idles crazy than stalls out?? HELPPP
Old Jun 20, 2011 | 08:52 AM
92ninjateggy's Avatar
Default Need Help FAST: Acura 1992 starts up idels crazy than bogs out and stalls?
I have a 1992 ACURA INTEGRA LS 1.8 A/T starts, runs and stalls, the S3 indicator light is always blinking, recently had the A/T shift cable replaced with a 94-01 cable that i had to modified. Could this be my problem?
THINGS IVE DONE ALREADY:
1.REPLACED FUEL FILTER
2.CLEANED ALL DISTRIBUTOR COMPONENTS
3.CLEANED IACV, FITV,
4.CHECKED INJECTORS FOR CLOGS
5.CLEANED THROTTLE BODY
6.CHECKED SPARKS PLUGS
7.REPLACED CAT W/ STRAIGHT PIPE
8.CHECKED TIMING BELT
Why does the S3 light flash and why does my car bog out and stall?
If anyone has any ideas please help me
Old Jun 20, 2011 | 09:02 AM
hatmanafro's Avatar
Default Re: Need Help FAST
Maybe a vacuum leak. Ceck all the little bullshit rubber hoses coming off the intake mani
Old Jun 20, 2011 | 09:06 AM
IVE CHECKED THEM FIRST BEFORE I REPLACED THE FUEL FILTER BUT ILL CHECK THEM AGAIN,
MY S3 LIGHT KEEPS FLASHING AND IT STARTS UP BUT IDLES CRAZY AND THAN STALLS
Old Jun 20, 2011 | 10:45 AM
Default 92 Acura Integra starts up but idles crazy than stalls out?? HELPPP
My 1992 Acura Integra starts up but idles crazy, bogs than stalls out.
I just recently had the shift linkage replaced it with a 94-01 linkage that had to be modified is this the source of my problem?
Also had the cat removed and replaced with a straight pipe.
replaced fuel filter
cleaned all distributor components
cleaned the IACV, FITV,
checked injectors for clogs
cleaned the throttle body
checked spark plugs
replaced cat with a stright pipe
checked timing belt
My S3 light is constantly blinking what might that indicate?
Ive checked for a vacuum leak doesn't seem to be the problem.
IF ANYONE CAN HELP ME WOULD MEAN A LOT!! ILL TRY ANYTHING TO GET MY BABY RUNNING AGAIN!!!!!
Old Jun 20, 2011 | 11:37 AM
1998GsRIntegra's Avatar
Ok, read this https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Then, stop typing in all caps.
Old Jun 20, 2011 | 11:52 AM
Default Acura 1992 starts up idels crazy than bogs out and stalls?
Thanks I'm a newbie at this posting!!
but need help with my 1992 Acura that starts up but than bogs and stalls out??
Any ideas??
Old Jun 20, 2011 | 12:29 PM
Give this a read http://forums.g2ic.com/archive/index.php/t-197558.html
Figure out what code(s) it's throwing.
Old Jun 20, 2011 | 12:51 PM
Just S3 is flashing on my dash..
The car turns on and idles but it idles crazy and than bogs and stalls out
I had the cat replaced with a straight pipe. And my linkage was also replaced but replaced with a 94-01 part could this be my problem?? Im getting spark just bogging and stalls out?? What could be the problem??
Old Jun 20, 2011 | 05:43 PM
fcm's Avatar
fcm
Old Fart
Default Re: 92 Acura Integra starts up but idles crazy than stalls out?? HELPPP
A blinking S3 light indicats a transmission fault.
How many times does it blink, the S3 light will come on for about 2 sec. when ign. is turned on, then it will blink a code, count the number of blinks. 94
PS, yes the modified shift linkage may be the problem.
Old Jun 20, 2011 | 06:53 PM
el crapitan's Avatar
before it dies, does the engine actually idle crazy? or is it just the tach acting erratic before it dies?
Old Jun 20, 2011 | 07:27 PM
checked spark plugs
checked timing belt
The S3 light blinked one time with the check engine on than went off.
TCM flashed the code 1, than 1,2. What does this mean??
Old Jun 20, 2011 | 07:28 PM
The engine bogs down than stalls out and makes a funny sound after. Like compression????
Old Jun 20, 2011 | 07:31 PM
its throwing code 1, than 1 2???
Old Jun 21, 2011 | 05:54 AM
I replaced the A/T shifter cable WITH A 94-01. Not the linkage. Would that cause my problems?? Also considering that the shifter actually doesn't go to S4 but from S3 to D skipping the other one completely. It is also throwing me codes 1. than 1, 2.
May be the guy who did the new shifter cable put in the wrong transmission fluid? Could that cause these problems?
Any insight would be helpful.
Thanks again
to4e hatch
Mar 18, 2010 05:47 AM
andrew54
Transmission & Drivetrain
Jul 31, 2009 04:59 PM
texasboy13
Mar 24, 2009 11:21 PM
DC_craze
Apr 12, 2005 09:26 AM
tirref22
Dec 22, 2004 07:04 AM
