Transmission & Drivetrain Gearboxes, Differentials, Clutches
94 civic dx Transmission repair questions
Old Jun 19, 2011 | 06:04 PM
Crustbucket2.0's Avatar
Default 94 civic dx Transmission repair questions
Yesterday I opened up my transmission to replace what I believe to be a bad Input shaft bearing. I also went ahead and replaced the mainshaft bearing while i was inside. I'd like to ask a few questions before i seal it up so hopefully I don't open it up for a long time.
First: I understand the transmission should be kept clean and from reading a few transmission rebuild articles I'm lead to believe that using brake parts cleaner or similar solvent is acceptable. Is this indeed true?
Second: I rotated the differential and it makes a rather loud whirring noise and also has what seem like "hard spots" in its rotation. It doesn't appear to be damaged at all but I really have no idea. Can someone describe what normal differential assembly should look/feel like?
Old Jun 20, 2011 | 08:44 AM
David @ Synchrotech's Avatar
Default Re: 94 civic dx Transmission repair questions
Brake cleaner is fine for cleanig the parts. After the bearings are clean, lube them with some MTF and spin them. If they are noisey or crunchy feeling, they need to be replaced.
Old Jun 21, 2011 | 07:09 AM
MR.johnson's Avatar
Clean the main and counter shafts out as well.
Old Jun 21, 2011 | 10:38 PM
Mista Bone's Avatar
D Tranny Guru
strip and clean the shafts as little bits of debris from the ISB going bad will clog the oil ports.
Just bought a 20 gallon parts cleaner tank to assist in doing this!
CivicDXdude
Feb 19, 2013 06:34 AM
VegasInvasion
Apr 27, 2009 08:45 PM
teamhonda_johnb
Honda Civic (2001 - 2005)
Mar 1, 2009 07:25 PM
Hanmin
Dec 26, 2008 11:44 AM
949
May 24, 2008 06:08 PM
