brake booster check valve
Old Jun 19, 2011 | 07:50 AM
cheeesboiger's Avatar
Default brake booster check valve
so i just did the brake booster check valve test on my car and i was wondering if i'm supposed to be getting a vacuum from the nipple of the check valve. i didn't get a vacuum from the check valve.
Old Jun 19, 2011 | 09:12 AM
Tyson's Avatar
Default Re: brake booster check valve
the source of vacuum is the intake manifold when the engine is running.
im not sure what you mean getting vacuum from the check valve, itself.
http://www.norcalcrx.org/tyson/pics/braketest.jpg
Old Jun 19, 2011 | 01:02 PM
ok i understand that i'm supposed to have a vacuum from the hose thats connected to the intake. i guess what i was trying to ask is if i'm supposed to get a vacuum from the hose thats connected to the brake booster? i'm getting vacuum from the hose connected to the intake but i'm not getting one from the hose connected to the booster. i replaced the check valve 4 different times. when i depress the brake pedal, i hear a hissing and my rpms fluctuate from idle to about 1600 rpms. i'm guessing my brake booster needs to be replaced. any opinions out there?
Old Jun 19, 2011 | 01:45 PM
bk7794's Avatar
Never knew what that was. I don't mean to thread jack, but I was figuring maybe kill two birds with one stone, would that valve be the cause of a low idle when the brakes are depressed?
Old Jun 19, 2011 | 01:52 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
The check valve itself, no.
OP - replacing the check valve has nothing to do with your problem. It sounds exactly like a your brake booster is in need of replacing. Your are getting the symptoms but another is your brakes will be stiff as well, due to the lack of vacuum assist.
Old Jun 19, 2011 | 01:53 PM
bk7794's Avatar
Alright, thanks.
Old Jun 20, 2011 | 09:30 AM
Alright, thanks.
thanks a lot for the info, i had a feeling it was the booster. that leads me to my next question. what brake boosters are interchangeable with my civic? i was thinking of getting one off an eg. i've also seen a few crx's with a brake booster at a junk yard along with a civic std. will any of those work on an si?
acarguy
Honda Fit
Aug 6, 2017 02:56 PM
Mad-Mike
Jul 9, 2011 05:22 PM
em1 Ziggy
Apr 17, 2006 04:08 AM
djnikko
Nov 5, 2004 08:02 AM
aalb1
Oct 22, 2004 07:06 AM
