7000rpm on b20b?
Old Jun 19, 2011 | 02:17 AM
hellaflushdb2's Avatar
Default 7000rpm on b20b?
so i just swapped in a 97 jdm b20b in my teg and did few runs shifting at 6700and accidently once at 7100 for a sec when i downshifted. when i got home i checked the specs on my motor and it said the redline is 6300. should i be ok i have a chipped ecu with a ls basemap tuned on a mystery motor. what should i shift at safely? it feels like it makes power untill 6700.
Old Jun 19, 2011 | 06:35 AM
1998GsRIntegra's Avatar
Default Re: 7000rpm on b20b?
Just a stock b20? Stock valve springs, cams, ect? My opinion...not much more than 300rpm or 400rpm past stock redline. The last thing you want to do is rev the **** out of it all the time and float a valve...
Old Jun 19, 2011 | 10:12 AM
hatmanafro's Avatar
Truth! ^^^.. but dont b20 and ls motors have the same head basically? I would say that its safe to run the ls redline
Old Jun 19, 2011 | 11:53 AM
el crapitan's Avatar
^^long as it's not a p8r head. only difference is the intake cam AFAIK
Old Jun 19, 2011 | 04:40 PM
Something else that just hit me...aren't the Jdm B20's labeled as B20Z motors, not the B20B's that are in the states?
Old Jun 19, 2011 | 10:56 PM
my motor is bone stock and b20z's are usdm
Old Jun 19, 2011 | 11:28 PM
hatmanafro's Avatar
B20z is just a higher CR version of a b20b
Old Jun 20, 2011 | 10:07 AM
the 99-01 b20b's are the same as b20z
Old Jun 20, 2011 | 06:56 PM
^^yup. so much discrepancy between with the b20's.
some 99-01's came with the p8r head as well
PabloM
Oct 13, 2013 06:57 AM
90DAkid
13
Mar 19, 2006 04:01 PM
Mr.E.G.
May 4, 2004 06:13 AM
hondaeg8
Feb 12, 2004 07:09 PM
USDMMARK
Sep 10, 2003 08:20 AM
