96 accord brake issues
hello im having some major brake problems....peddle goes to the floor at times then i have good strong brakes so i thought it was air in the lines, bleed the lines and had good pedal for about 3 hours then back to the same thing,pedal to the floor now its to the point of having to down shift and use the e-brake just to come to a stop im thinking master cylinder but im not sure
You have a leak in your system. It's most likely your master cylinder, but I would give everything a good once over to make sure it's not leaking somewhere else.
Yup, I say it's also the MC. Mine did the same last summer. It'll slowly sink; especially, on them hot days. Finally got around to replacing it last year, and problem solved.
96 GSR-T
Jun 10, 2008 07:31 PM
