transmission help
Old Jun 18, 2011 | 10:38 PM
spens 91 Ef's Avatar
Default transmission help
i just got a a si tranny from a junkyard and when i went to put it in my car it wouldnt line up so counted the teeth it had 21 so i was wondering what is the main shaft from if its not d series
Old Jun 18, 2011 | 10:46 PM
90civicstdgold's Avatar
Default Re: transmission help
88 Si has a 21 spline count on the clutch spline
89-91 Si has 20 splines
This could be where your problem lies
You will need a clutch for the 88 Si transmission
Old Jun 18, 2011 | 10:49 PM
that so weird, i believe you even the lining tool from a y7 lines up to my clutch
Old Jun 18, 2011 | 10:54 PM
Yup, you sir have the 88 Si transmission
Old Jun 18, 2011 | 10:55 PM
This thread below touches a little bit on the differences
It may be helpful to you...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/what-look-identify-si-tranny-1551508/
Old Jun 18, 2011 | 10:56 PM
its that 1 and only year in all the 88-00 that have different teeth
Old Jun 18, 2011 | 11:00 PM
Yeah its odd, but that's the way it is I guess
Here is another thread as well that could give you some insight on what to use to make your transmission work for your setup.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/stock-clutch-fitment-guide-2284956/
I hope all of this helps for you......
Old Jun 18, 2011 | 11:05 PM
thanks for the help much apreciated
anth9998
May 18, 2008 11:14 AM
si0385.
Dec 23, 2005 06:58 PM
88EF
12
Apr 9, 2003 03:28 PM
kyle h.
Jan 14, 2003 08:33 PM
