Suspension & Brakes Theory, alignment, spring rates....
Lowering kit trouble
Old Jun 18, 2011 | 04:55 PM
97accordbuildlx's Avatar
Default Lowering kit trouble
i recently tried to install a megan racing coilover kit on my 97 accord. the stock springs are 4.5 inch wide and the new springs are 3.5 inches wide. the piece the spring sits on is made for 4.5 inch springs. the 3.5 springs wont sit correctly. sorry if this is confusing but i tried to explain it as best as i could. what is the best way to fix this? im wondering if the lowering kit is made for a civic, im assuming they use 3.5 inch springs. accords being heavier need 4.5's maybe? so im basically asking where i go from here. whats the best way to fix this issue. thanks
HERES A LINK TO DESRIBE THE PIECE THE SPRING SITS ON: http://www.shockabsorbersworld.com/g...suspension.jpg
Old Jun 18, 2011 | 04:57 PM
Default Re: Lowering kit trouble
******and the piece the spring sits on is on my stock shock. sorry im sure theres a name for the piece im talking about but i dont know vey much about suspension. this is the first time ive ever really messed around with susp.
Old Jun 18, 2011 | 05:56 PM
grumblemarc's Avatar
The Grumpiest
The piece that the sleeve sits on is called the perch. The piece that the spring sits on is called the collar. You do NOT mount the springs directly onto the shock like the old springs were installed. It doesn't matter in the slightest how wide the original springs were as long as the sleeve fits snugly onto the shock, usually with o-rings installed to keep it from moving around and eventually mushrooming the sleeves.
Old Jun 19, 2011 | 09:50 AM
is there anyway you could send me a link for a picture of how theyre mounted then? thanks for the help
Old Jun 19, 2011 | 10:44 AM
The Grumpiest
Have you tried Google?
Old Jun 19, 2011 | 11:37 AM
well yea but googles flooded with irrelevant pictures that dont really show me how to mount them. im just going to take one of the shocks and the kit down to goodyear so they can show me how to mount it.
civicmanyep
Suspension & Brakes
Jan 10, 2012 12:00 PM
EX R8ED
Oct 4, 2003 12:52 PM
H23A1LUDE
Apr 11, 2003 01:11 PM
Aron Parsons
Oct 9, 2002 01:04 PM
PnX-R
Apr 27, 2002 03:02 PM
