B18C1 won't Rev past 2500Rpm
2000 GSR, B18C1, OBD1 ECU, won't rev past 2500Rpm
Brand new dizzy, cap, rotor, plugs
Unplugged the IAC and won't past 1500Rpm
Unplugged the MAP and car cut off.
ecu jumper. blue connector near ecu tray. should have 2 pins. paper clip from 1 pin to the other. turn key, then count the CEL flashes. look it up for a better example
Mini-Cooper? This is a Honda forum!
Even still, if you cannot pull codes no one can help you accurately. And even if you could pull codes using the plug how d you get them to show up anywhere?
B18C1 is still Honda no matter what car it is in, right?
It's a Honda engine no question. But it's a hybrid chassis so a lot of the usual troubleshooting techniques will no longer apply. Especially if you cannot pull a code.
Type 56
Dec 20, 2018 08:19 AM
