Engine rebuild (D16Z6)
Old Jun 18, 2011 | 03:56 PM
rickjamemotorhe's Avatar
Default Engine rebuild (D16Z6)
I am rebuilding this motor and have ran into this issue,..My crankshaft is stiff after I torque all the rod caps to spec and then try to rotate the crank. It requires two hands and ratchet to turn rotation (seems very stiff). I have removed the two center rod caps and then the cranks turns freely. What am I doing incorrect.
Old Jun 18, 2011 | 08:11 PM
GhostAccord's Avatar
Default Re: Engine rebuild (D16Z6)
What are the measurements that you got when you measured the clearances for the bearings?
CaliforniaDad
63
Apr 27, 2012 10:27 PM
Jdm03
Aug 24, 2011 04:56 PM
rickjamemotorhe
Jun 18, 2011 08:17 PM
