FS: 94-95 Chipped OBD1 P72 ECU Launch Control / Shift Light
text me 626-235-0008
location Rosemead CA
Got a OBD-1 Chipped P72 ECU with Launch Control and Shift Light. When i had this ecu on my car, i had full bolt-on intake / header / 68mm throttle / intake manifold / stock cat / apexi noir catback system. Ran Perfect no problem. If i remember correctly, these are the specs:
Vtec Engaged: 5700RPM
Redline: 8500RPM
Launch Control: 4500RPM
Shift Light: 8200RPM I BELIEVE
Type R Base I BELIEVE
NO SPEED LIMITER
MAKE ME AN OFFER, TEST IT BEFORE YOU BUY
. I WILL RIDE WITH YOU IN YOUR CAR.
Also got a Brand New USDM Replica 94-97 Type R Lip $55 Bucks pick up
Redline: 8500RPM
NO SPEED LIMITER
. I WILL RIDE WITH YOU IN YOUR CAR.Also got a Brand New USDM Replica 94-97 Type R Lip $55 Bucks pick up
dravesef
Jul 15, 2009 10:46 AM
Need obd1 p72 help ASAP-Was told chipped to 4400/9000 specs - Ecu appears stock but only revs to 700
QualityMaterial
Jul 13, 2006 11:07 AM
VNTEC
May 25, 2004 12:52 PM
