Transmission & Drivetrain Gearboxes, Differentials, Clutches
00 civic si S4C transmission question
Old Jun 17, 2011 | 10:34 PM
wohpony's Avatar
Default 00 civic si S4C transmission question
Hi,
I'm about to pick up a 2000 Civic SI that has no 3rd gear. I found a LSD S4C transmission for sale to replace the current tranmission with. My question is what should I look for when I go to pick up the S4C transmission? Also is this a good swap for a 2000 Civic SI?
Old Jun 18, 2011 | 11:06 AM
94dxcoupe's Avatar
Default Re: 00 civic si S4C transmission question
I've never seen an S4C transmission with a factory LSD. I'd be pretty skeptical goin to pick that one up...
Old Jun 18, 2011 | 08:59 PM
wohpony's Avatar
I read in a post somewhere that the S4C Transmission is from a SIR and is a very good transmission. Is this false info?
Old Jun 21, 2011 | 07:11 AM
Gearspeed-Performance's Avatar
It may be a CTR transmission. Hard to tell without seeing it in person. Make sure that when you look through the differential opening that you don't see a differential pin going across. A differential pin going across would indicate a non-LSD trans. If it has an S4C sticker and no diff pin going through it can either be a CTR or a 99-00 Civic Si with an LSD. Both the CTR and 99-00 Civic Si have the same gear ratio in 1-5th gears with a 4.40 final drive ratio. The shaft gearing is great...I would bump up the final drive to a 4.7 or 4.9 depending on what you plan to do with the car.
noey
Honda Civic (2006 - 2015)
Jan 15, 2008 10:30 AM
Nicram
Sep 27, 2005 08:02 PM
B18C5-EH2
Aug 1, 2004 02:17 PM
turboex
May 11, 2004 05:31 PM
